Rocking window problem found!
Old Feb 10, 2003 | 01:17 PM
Shawn84&92's Avatar
Shawn84&92
Default Rocking window problem found!
When my drivers window is partially down, it would rock front to back. It doesn't do it when it is fully up or down, because the window sits in a groove when totally up or down. Anyway, the problem is the plastic part that the window bolts to. It is a two piece part that is on a hinge and when it breaks, it is still connected but it has more play in it. A digital camera would save me alot of writing right now. I drilled two small holes in the two pieces and zip tied it together. This took out a lot of the slack, but it really needs to be bonded together.
For those of you with this same problem , it looks like it will not completely fail, if you can live with the rockin, live with it, because the only solution is to buy a new regulator.
Shawn
Old Feb 10, 2003 | 07:44 PM
Rich_01659's Avatar
Rich_01659
Default Re: Rocking window problem found! (Shawn84&92)
mine rock and i'll take your advice and live with it. I removed the door panel once to check it and found nothing helpful.
