Please somebody with c4 map L98 engine quick easy help
I replace map connector and probably I lost the correct order
could you please in your map the wire color order from left to right
on my car the color options are :
1.- olive green
2.- tan
3.- pink-black
at this moment I have from left to right installed 5v, signal, ground
I only found 1 photo of map sensor at this site, with no color match
voltmeter, engine stop, line signal have almost 5v like 5v reference, when I aplied vacuum with pistol vacuum, signal volt decreases, this is normal or is inverted
tunerprort, engine stop map reads 101, and decreases at cranking
