Removing Tensioner Pully
Old Mar 4, 2025 | 02:58 PM
cameron11j's Avatar
cameron11j
Default Removing Tensioner Pully
Hi all, I had a quick question, I am currently trying to remove the tensioner pully. When I loosen the 15mm bolt that holds the tensioner in, it does not clear the frame. It just needs a few more spins but will not come out due to that, any ideas? Thanks.
Old Mar 4, 2025 | 03:22 PM
ULTM8Z's Avatar
ULTM8Z
Probably have to take the tensioner assembly completely off the serpentine bracket then.
Old Mar 4, 2025 | 04:32 PM
s carter's Avatar
s carter
It sounds like you're motor mounts have settled a bit, at the best that clearance is tight so 30+ years old probably a little soft now. So if you have a floor jack and a stout wide board get it under the pan give a pump or 2 see if it's enough to get that last hair
To Removing Tensioner Pully
