Hey all- I sprung a small drip on the front passenger shock of my 91 ZR1. I looks looks like a shock swap is in order as I have 92k on the car. No codes but the age and mileage say "lets go." I have a couple of questions:
I have a brand new (in the box un opened) full set of Bilstein FX3 adjustable shocks that I was saving. I bought these several years ag in anticipation of a swap off my current set. They have been in my garage for probably 4-5 years. Does anyone see any age related issues (seals leaking?) as to why there would be a problem swapping these out?
Are the C4 Corvette shock bushings universal/inter changable that I coudl order from a local part store? I just drive on the street a couple of times a month so a no need for "high performance" bushings.
Also, is there any thing I need to do to set the "clock" on the FX3 shock when I put the Actuator back on or is it self adjusting?
I dont think youd have any issues using the ones you bought and stored... IIRC, (been a few years) when I replaced the ones onmmy 90 & 92 ZR-1's, the actuators can be put on in any position. As far as the bushings, Im not 100% sure.... I suppose you could get a few measurements of the ID & OD of the bushings and see if theyre the same.
I agree with the above on all points. If it were me, I would reuse the existing bushings. New ones are only available in polyurethane and they mess with the position of the rear upper shock sleeve, as they are too hard and don't allow an angle for the upper sleeve cover. Then it rubs on the shock body itself, etc...
The shock actuators will do a full travel test at key on, so they read that and reset for full range every time. The chip in the controller is pretty smart about this.
Thanks- I had a heck of a time finding rubber bushings, but ending up finding a set at Zip and ordered them. I agree; non bueno on the polyurethane. So, my project got moved to next weekend.
Curious what the part number is. Because as stated it was only poly available. And there is a difference between FX3 and base level shocks.
I'll have to shoot you the part number once I get the package (thursday). These are FX3 specific bushings and you are right there is a difference in the hole size as the shaft on the FX3 is slightly larger.
