94 LT1 sudden abrupt onset overheating
I've heard mixed things about the running temps on these cars but my completely original system sits around 210 and only ever once got to 225 on a 95 degree day with ac on full blast.
Prior to my follow up to your kind replies, i have been reading on this topic, finding a wealth of information.
First off, engine cool, last night i bled the air from the two air bleed sites, LH side under the throttle body and RH side above thermostat.
I filled the surge tank to the neck. The overflow tank fluid was at the cold level.
As the engine came to temp, violent frothing began coming out the surge tank opening.
All large hoses were firmly distended with engine running and fluid was hot.
Heat in the cockpit coming through vents hot.
No overheating diagnostic codes were triggered.
My answers In order of comments:
@pltmgr I am going to replace the new ACD 180' stat with the new Mishimoto 160' stat tomorrow. Steady stream of coolant flowing through the lower line into the surge tank.
@OneRedVette There is no trace of coolant on the engine oil dip stick.My fans both turn on and run.
@signify How can i diagnose a collapsed hose? If i remove the hose, can i visually see the collapsed area?
@radar502 Both fans turn on and stay running. Old hoses collapsing >>> does tis occur on the inside of the hose and therefore unable to see a collapse from the outside? I did not notice any hose collapse on the outside. My radiator cap is a new ACD; i realize just because a part is new does not mean the part can be defective.
@81c3 Your point on the surge tank leaking air is well taken. Prior to this event, i had repaired the leak with JB Weld and prior to the JBW repair, even though the leak was miniscule i was not having an overheating problem. I will definitley take into consideration replacing the surge tank. There was steady coolant flow into surge tank from lower hose. Fans turn on and run.
@OldStingRay Yes, i thoroughly cleaned the AC condensor prior to istalling the new Dewitts single row.
My plan of attack tomorrow:
1. Remove and test the new ACD stat
2. Replace the new ACD 180' stat with the new spare Mishimoto 160' stat. Start engine and observe engine temp rising.
3. Bleed both valves, throttle body side and stat housing side.
4. I replaced the lower rad.hose with an Autozone Duralast when i replaced the radiator. Can i visually diagnose a collapsed radiator hose? Is it good practice to just replace all the passenger side hoses regardless? What are your thoughts on best radiator hose kit? My thought is stay with AC Delco.
5. fwiw, the coolant pump is not leaking. it was replaced new 7,000 miles ago. I am assuming because there is a steady flow of coolant entering the surge tank from the lower hose, that the pump is circulating fluid.
6. I understand the excessive heat of coolant would account for the violent frothing. I had left the cap off the surge tank as my intent was to observe for air bubbles and add coolant as bubbles burped out, as the videos i watched, there should be no excessive heat of coolant, just a gentle recirculation with belching bubbles if there's air in the system.
7. I have been looking up info to diagnose if the coolant pump is moving coolant, but not found what i consider to be a definitive answer.
IS THERE ANYTHING ELSE I NEED TO CONSIDER that i have not asked?
Thanks in advance and kind regards.
I replaced my water pump Hi end one and very hi end state that fixed it checked the old pump seemed to be working fine and tried not one but three states nothing helped . This 93 is my 4th C-4 all at one time or another all ran hot, just have to go through the steps, the weird part is very rare ya really know what was really going on with it just have to hit on the problem and BAM stops running hot , GOOD LUCK .. One mo thing nothing weird about your C-4 this as far as I can tell this is the prossess ..
