Valve float in stock LT4?
Old Mar 10, 2025 | 02:46 PM
rremesal's Avatar
rremesal
Default Valve float in stock LT4?
Team,
I'm trying to chase down a high-RPM stumbling/bucking problem. After figuring out the fuel pump was not keeping the pressure up above 5K making the car nosedive, I replaced the old unit with a new one and that issue was resolved. However, a new issue or perhaps an issue that was masked by the fuel pressure situation has come up.
The car pulls strong all the way to 5.5K RPMs...at that point I get a bucking/stumbling/misfire causing a lack of acceleration. I have no codes, and I have replaced quite a few parts as routine maintenance (pretty much ALL sensors and ignition components). The original Opti is still in place and was freshened up a few months back. The car is driving very nice, actually.
Could this engine be experiencing valve float even though is all stock?
Old Mar 10, 2025 | 03:37 PM
AZSP33D's Avatar
AZSP33D
Check/replace the fuel filter first if you haven't already... also inspect the metal fuel lines to make sure they are not kinked (mine were near the rear wheel well)
Old Mar 10, 2025 | 04:26 PM
rremesal's Avatar
rremesal
The filter has been replaced twice.
What am I looking for...a pressure drop?
Old Mar 10, 2025 | 04:39 PM
AZSP33D's Avatar
AZSP33D
Visual inspection... follow the line under the car
Old Mar 10, 2025 | 05:16 PM
rremesal's Avatar
rremesal
I know what you are saying....my questions is: Am I diagnosing a fuel pressure problem as a possible cause of the power loss?
As I stated in my original post, I have ~42psi of fuel pressure under load all the way up the RPM range.
Old Mar 10, 2025 | 05:55 PM
pltmgr's Avatar
pltmgr
Are you hitting the rev limiter? Maybe your tach could be inaccurate?
Old Mar 10, 2025 | 09:00 PM
rremesal's Avatar
rremesal
This is something I thought about and have to validate. Through data logging.
Old Mar 11, 2025 | 03:30 AM
Aardwolf's Avatar
Aardwolf
Bucking etc symptoms I think of spark plugs first.
Old Mar 11, 2025 | 05:00 AM
rremesal's Avatar
rremesal
Those are brand new...first thing I did "just in case".
Old Mar 11, 2025 | 07:37 AM
XLR8-R's Avatar
XLR8-R
How many miles on the car? If it's more than ~80k, valve spring check would be my next step. Just pull springs on number one. It's not too difficult. Otherwise it still might be the opti even though you have been in there. Also check spark plug wires if you haven't already of course.
Old Mar 11, 2025 | 10:15 PM
AZSP33D's Avatar
AZSP33D
Not pressure, flow... but don't worry about it.
And you didn't state anything like that in this post... what original post. Good luck buddy.
Old Mar 12, 2025 | 10:13 PM
jmalez's Avatar
jmalez
sorry but its your opti
To Valve float in stock LT4?
