LT1 Spark Plug Install Tips
Old Feb 11, 2003 | 09:28 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default LT1 Spark Plug Install Tips
I know somewhere around here there are some tips to installing spark plugs in an LT1. 2 of the plugs are a booger to get too. Could someone please remind me of those helpfull tips before I get started today?
Thank you.
Eric
Old Feb 11, 2003 | 10:17 AM
Rich_01659's Avatar
Rich_01659
Default Re: LT1 Spark Plug Install Tips (HOWSER)
I've changed my plugs twice and my advice is - if it is in your way, move it - also the passenger side is the worst so do it first, those rear 2 may require the spark plug socket and a wrench combo. and a worm engine is ok but not hot - cuz it will burn you :D use some kind of anti sieze for the install and don't force anything. oh yeah, first time give yourself about 2 or 3 hours. make it fun. change the oil and air filter while your at it. Wires are next but way more complicated. Good Luck :cheers:
Old Feb 11, 2003 | 11:11 AM
Dan Parker '96's Avatar
Dan Parker '96
I haven't found the spark plugs that hard to change. But when I did my rebuild I left the stock spark plug wire harnesses off (except for one). It's not as pretty, but the plug wires are now farther away from heat sources and I've got twice the room for my hands.
Old Feb 11, 2003 | 01:07 PM
STL94LT1's Avatar
STL94LT1
On the #8 plug use a spark plug socket and an open end wrench to remove/install.
Old Feb 11, 2003 | 01:37 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: LT1 Spark Plug Install Tips (STL94LT1)
I've used this methos and a 1/2" breaker bar attached to a plug socket. These seem to be the two best ways, although I've been told it is easier to access from beneath.
Old Feb 12, 2003 | 10:52 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Thanks guys! I do agree that the passenger side looks to be the headache in the process.
Later.
Eric
Old Feb 12, 2003 | 12:21 PM
Lord Odin's Avatar
Lord Odin
I find the passenger side to be extremely easy with the exception of the rear one. The driver side is the real pain for me. :smash:
Old Feb 12, 2003 | 07:38 PM
Lone Ranger's Avatar
Lone Ranger
I becoming a sicko. I'm starting to like changing plugs.
Old Feb 12, 2003 | 08:40 PM
JayH's Avatar
JayH
Default Re: LT1 Spark Plug Install Tips (Lone Ranger)
:iagree: It's a heck of a lot easier than most other jobs on the car.
Jay
Old Feb 12, 2003 | 08:48 PM
bogus's Avatar
bogus
it would be much easier if we had an extra joint between the wrist and elbow.
Old Feb 12, 2003 | 08:58 PM
Lone Ranger
Default Re: LT1 Spark Plug Install Tips (bogus)
And also, once you've done it a few times, you get a feel for the placement and angle of the spark plug holes so getting the blind ones started (#8, #7, #6 for me) is a lot easier. :reddevil
Old Feb 13, 2003 | 04:08 PM
6 speed Sid's Avatar
6 speed Sid
Get an assortment of extensions lengths, universal (swivel), and a plug socket that can be turned with a wrench before you start. GM could have made it a lot easier with just a change or two. Sid.
Old Feb 13, 2003 | 04:22 PM
Yellow95's Avatar
Yellow95
Default Re: LT1 Spark Plug Install Tips (6 speed Sid)
Someone on the forum clued me into a fuel line hose to put on the plugs for removal and replacement so you don't have to use the wrench and extensions for the entire length of the thread. This worked great on the #8 plug.
Note: the book says the plugs are good for 100k miles. My philosophy is, if ain't broke, don't fix it.
Old Feb 13, 2003 | 04:53 PM
Lone Ranger
Default Re: LT1 Spark Plug Install Tips (Yellow95)
:lolg:
Old Feb 13, 2003 | 06:20 PM
94redrag's Avatar
94redrag
I just changed mine last weekend(Bosch +4's) and found that if you remove the center section of the wheelwell(the section right above the shock) Theres only 5 bolts and a couple of clips holding this piece on. You'll have a lot more room to work, especially on the drivers side. You'll be able to go in underneath the ABS and brake booster to get to the plugs. The passenger side is easier to except for #8 which is a real PITA no matter what. The socket and wrench is about the best way to do #8. Also, don't forget to put some dielectric grease inside the boots in case you have/need to change the plugs/wires at a later time.
Later Zane
Old Feb 13, 2003 | 06:48 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Currently Corvette-less
Default Re: LT1 Spark Plug Install Tips (94redrag)
Spark plugs are relatively easy. to change. I find it easiest to pull the front tires and go in through the wheel wells with a long extension. I use a 3/8" X 24" extension along with a 3/8" universal for most of the plugs, including the one behind the brake booster on the drivers side.
:seeya Purp
Old Feb 13, 2003 | 07:01 PM
Lone Ranger
Default Re: LT1 Spark Plug Install Tips (PurpleC4)
I don't remove nothin'. I just smear some warpaint on my face, remove long sleeves, make sure anyone offended by sailor-class profanity is well out of earshot, and have at it. :smash:
:chevy
About 2 hours, three beers, 3 - 4 good wrist and forearm nicks and scrapes later and I'm all done and a happy camper :hurray:
:seeya Purp
To LT1 Spark Plug Install Tips
