No crank, no start, runs when bump started.
Old Mar 23, 2025 | 02:06 PM
rwigginc4's Avatar
rwigginc4
3rd Gear
Default No crank, no start, runs when bump started.
First time owner of a c4 and I’m a little lost. Turn the key cluster lights up, security light turns off, and I can hear the fuel pump kick on. Attempt to start and only the seatbelt light on the cluster goes out. Previous owner has installed a vats bypass and an aftermarket radio. The wiring harness underneath the driver side kick panel has been messed with. Tachometer doesn’t work. Attempted to bypass the clutch switch and made no change. But when bump started it runs like a champ. Any help would be appreciated.
Old Mar 23, 2025 | 02:10 PM
vetteLT193's Avatar
vetteLT193
Bad starter, bad ground to the starter are the first spots to look
Old Mar 23, 2025 | 02:32 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
YMMV...~00:43...
Old Mar 23, 2025 | 04:44 PM
rwigginc4's Avatar
rwigginc4
3rd Gear
Bench tested the starter and it didn’t do anything, didn’t have my circuit testin tools on hand so I’m gonna check during replacement. Thanks for a starting point.
Old Mar 23, 2025 | 06:01 PM
stew86MCSS396
I think I misunderstood what you meant by “bump starting…” hence what I posted. As long as the start enable relay is working than what you said…
Old Mar 23, 2025 | 08:44 PM
pltmgr's Avatar
pltmgr
Im confused by what you mean by bump staring.
Old Mar 24, 2025 | 12:48 PM
rwigginc4's Avatar
rwigginc4
3rd Gear
Pushing the car then dumping the clutch, fires right up.
To No crank, no start, runs when bump started.
