Radiator surge tank
Old Mar 30, 2025 | 07:01 PM
95wht6spd's Avatar
95wht6spd
Default Radiator surge tank
I replaced the cap on my surge tank last year, I had a very difficult time removing, had to attempt several times on different days, and ended up using channel locks with a lot of wiggling and pulling. When I put the new cap on last year, I tried removing and had the same issue, but left it alone. It is very tight, but I can twist it to where it should come off, and there is some movement (see-saw on each side), but some part of it still catches on filler neck.
I tried again recently, and could not remove it, even with channel locks. Somehow the filler neck must have been deformed over the years. I guess my only option is to buy a new surge tank, unless someone has a repair idea?
Old Mar 30, 2025 | 08:03 PM
Whaleman's Avatar
Whaleman
You must mean the pressure tank as the surge tank just has a plastic cap. If it looks like a regular radiator cap you have to turn and then PUSH down and continue to twist off. Dan
Old Mar 30, 2025 | 08:21 PM
95wht6spd's Avatar
95wht6spd
Yes, they call that the surge tank
Amazon Amazon
The plastic one in the front is the overflow or expansion tank. I know it is confusing.
I'll try the cap again, but I used to not have issues with it.
Old Mar 30, 2025 | 10:37 PM
pltmgr's Avatar
pltmgr
On my 96 I have to push down and use a channel lock to remove the cap. The fact that Im old and weak doesn't help but cap is more difficult, for some reason, to remove than other radiator caps I have dealt with.
Old Mar 31, 2025 | 08:51 AM
Whaleman's Avatar
Whaleman
I am old and getting weaker also. I have found the more it is taken off the easier it is. I think the rubber seal sticks. I take a very small amount of grease and wipe the rubber. This helps a lot. I do see this is called a "surge" tank but I hope we can all agree nothing really "surges" into and out of this tank. It stays plum full all the time. Dan
Old Mar 31, 2025 | 10:15 AM
dburgjohn's Avatar
dburgjohn
When I was still working as a mechanic (decades ago) some of my customers complained about trouble getting cap off (and not just older ones). They were not pressing down enough before turning and were not clearing the locking tabs. After explaining about "never open hot" they were told to put a rag over the cap to protect hand, push down hard with both hands then turn. Oh and rightey tightey lefty loosey lol.
Old Mar 31, 2025 | 10:38 AM
Whaleman's Avatar
Whaleman
I agree. As I have moved into my 70's that cap spring has got stronger. Dan
Old Mar 31, 2025 | 10:44 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
High fill reservoir is what the FSM calls it. Just totally random opining here...
Old Mar 31, 2025 | 11:46 AM
95wht6spd's Avatar
95wht6spd
I tried it again, and it was easy, came right off. I feel dumb. I was thinking the tabs, were to stop from turning the cap too far when removing. I've only removed the cap a few times over all the years, and remembered it required you to push down and turn, but had it in the wrong order. I'll remember next time.
Probably confusing because a lot of safety caps on bottles, require you to push down first, then turn.
Thanks for the help!
Old Mar 31, 2025 | 06:15 PM
Whaleman's Avatar
Whaleman
I knew that was it because, being honest here, the same thing confused me a couple of years ago. Now I remember and, I suspect, you will always remember also. Dan
Old Mar 31, 2025 | 07:55 PM
BET VETTE's Avatar
BET VETTE
And the purpose of that tank is really for?
Old Mar 31, 2025 | 09:26 PM
95wht6spd's Avatar
95wht6spd
Other than for filling the system with coolant, and connecting to the expansion tank for overheating, IDK.
Old Mar 31, 2025 | 09:34 PM
Whaleman's Avatar
Whaleman
It does increase the volume of coolant. Dan
Old Apr 1, 2025 | 08:17 PM
BET VETTE's Avatar
BET VETTE
So basically two coolant tanks except one is see through
To Radiator surge tank
