Engine swap woes.
Old Apr 13, 2025 | 06:25 PM
Eightrac's Avatar
Eightrac
Default Engine swap woes.
I have a 1988 with the 700R4. It was a bit of a basket case electrically so I've done away with the TPI and the L98 altogether and am installing a Smeding Performance power adder 383. The aftermarket block has the oil pressure port near the bell housing flange instead of at the rear of the intake manifold, so installing the oil pressure switch and sensor are out of the question. There just isn't enough room to install them in that place.
Mind you, this car is now carbureted and most all of the unneeded wiring has been removed. I know the ECU needs the oil pressure switch to run the fuel pump. Can I just jump that connector and delete the oil pressure switch to force the ECU to run the pump all the time? Will it turn off with the key?
I have enough room at the front of the engine for the oil pressure transmitter to monitor oil pressure via the gauge, but not both transmitter and pressure switch.
Old Apr 13, 2025 | 09:46 PM
IHBD's Avatar
IHBD
Pro Mechanic
If it is now carbrueted, why will you retain the "ECU"?
For safety, you don't want the pump to run if the engine is not running. So you will still need a dedicated oil pressure switch for the fuel pump. I suggest a 3-terminal, single pole, double throw switch. (Use "1971 Chevrolet Vega" for your search. The Vega had an electric in-tank pump but was carb'd.) The Common terminal is to the pump. The Normally Open terminal is to a fused Hot in RUN (IGN) source. (In GM wiring, this is usually Pink at the ignition switch.) The Normally Closed terminal is to a fused Hot in CRANK source. (In a C4 this is Yellow at the Ignition switch. There may also be a CRANK fuse in the fuse box, or the CSINJ fuse behind the radio. These wires will be purple or pur/wht).
When starting, with no oil pressure, the pump will run in the START position through the NC contacts. When oil pressure rises, the pump is now powered by the IGN through the NO contacts. If you take the power for the crank terminal prior to the neutral safety switch (yellow wire), you can "prime" the pump and carb by placing the shifter in drive or reverse so it won't crank, but the pump will run in START.
Old Apr 14, 2025 | 08:09 AM
FostersPerformance's Avatar
FostersPerformance
Also, on my engine, my oil pressure switch is installed in the port above the oil filter. Plenty of room there. Mine is on a T fitting along with fuel pump switch. You can also install one near distributor on top of block, but its tight there.
Old Apr 14, 2025 | 12:32 PM
IHBD's Avatar
IHBD
Pro Mechanic
If there is only room for one sender, you could use the 1990-up combination sender / pressure switch to control a SPDT (5 terminal) relay wired as the SPDT switch suggested in the above posts. Use the pressure switch contacts in the sender to control the relay. Adds a little complexity and failure points, but doable.
There should be room off of the block port above the oil filter. Be creative with fittings. If there isn't room because of headers, use a braided hose extension to a remote location for the sender and switch.
To Engine swap woes.
