Codes??
Old Apr 14, 2025 | 04:13 PM
PologreenSuperchargd's Avatar
1st Gear
Default Codes??
Hi guys… I need some help.
My 94 is having an electrical issue, but I am unable to get the codes with any of my Obd1 or obd2 readers.
is there an onboard code reader?
Old Apr 14, 2025 | 09:47 PM
dburgjohn's Avatar
dburgjohn
Old Apr 15, 2025 | 07:38 AM
88StingrayEnjoyer's Avatar
88StingrayEnjoyer
Cruising
If you put a wire between the top right and second from top right pins on the ALDL Connector and turn on the car to the accessories (second detent, eight before engine start) you'll get the codes out of the annunciator panel above the stereo. It'll flash "12" on the service engine soon lamp. It'll be one flash, then two flashes, I think three times then it will start flashing any malfunction codes the ECM picked up.
Old Apr 15, 2025 | 11:25 AM
IHBD's Avatar
IHBD
Pro Mechanic
Originally Posted by 88StingrayEnjoyer
If you put a wire between the top right and second from top right pins on the ALDL Connector...
The OP has a 1994 which does not have the style of ALDL you describe. The picture in Post #2 shows both style ALDL connectors, and the years for each style.
Old Apr 15, 2025 | 11:34 AM
88StingrayEnjoyer
Cruising
Oh yeah you're right. I apologize my mistake.
To Codes??
