85 TKX swap speedometer tuning woes
Today I finally decided to tackle installing the Dakota Digital SGI-5C to make the speedometer work. With the help of some older threads about using this exact same adaptor, I tapped power and ground and intercepted the signal wire at the gauge cluster. Turned on the car and it works! The adaptor lights up and there's speed showing on the dash for the first time since I've owned it.
Here's where things get weird.
Using output 1 with all 4 switches off, the car says I'm doing 133mph when I'm actually doing 40. No big deal: I switch to output 3 per the instructions. Sure enough, this is MUCH closer, but still reads about 12 mph high. Okay, I'll just use the up/dwn buttons to tune it while the car is driving. Only they don't do anything. Pressing them repeatedly or holding them doesn't seem to have any effect. I tried flipping switch 3 to the on position, which makes the car read super slow, but the up switch doesn't work in this scenario either.
Even weirder is after I sat in my driveway with the car off for a few minutes trying to figure it all out, I suddenly couldn't get the car to start. It sort of seemed to smell really rich when this happened. I let it sit a few minutes and unplugged the battery for about 30 seconds before trying to start it again, which took 3 tries and had it running pretty rough for the first few seconds when it finally did start. It leveled out and I was able to drive it around but I'm still spooked since all I've messed with was the dash wires.
So my questions are:
1. Does anyone know how to program a Dakota Digital SGI-5 rev C or similar model?
2. Would the ECM suddenly having (inaccurate) vehicle speed data cause it to mess up the fuel mixture? Or is this maybe a completely unrelated problem?
Output 3 is the one you want.
Switch 3 ON changes the calibration by 50%. Ie 4,000 Sw 3 OFF, 8,000 Sw 3 ON. If you're 12 MPH high at 40MPH that's about 30%.
Did you try Switch 4?
Lastly the up / down buttons. The way I read it, you enter "coarse" or "fine" adjustment by holding a button then turn the key to RUN. Looking at the tables, fine is really fine. You may not see any change in speedo in fine. Re-read the section for entering coarse and fine, and using the LEDs to verify what mode/status the unit is in.
Application #3 has a formula to compute the new calibration ratio. But you need to know the existing ratio. This can be done with the buttons and the key. To make it read lower, you use a lower ratio. It's simple math. True Speed / Actual Speed X current calibration ratio = New calibration ratio. I believe this is the method I used 20 years ago. More accurate and quicker too.
I have no idea how speed input could affect a failure to start. There are some calculations that use speed like deceleration fuel cut off (DEFCO) and the IAC is positioned based on speed. Hopefully it won't do that again.
You probably have it working, but here's some ideas and suggestions. Enjoy your Tremec.
I've looked at the chart in the back of the instructions but I can't really make heads or tales of it. It's got "course" "fine" "cal hi" "cal lo" and "tach". Says cal hi/lo represents switch #4 on/off. Are the numbers under course and fine the number of led flashes that the unit will show when asking it for mode? And then the numbers under cal lo/hi the multipliers that fit into the equation for new ratio?
Determine the existing calibration.
In the table of calibrations, ignore "tach". The first two columns are the Coarse and Fine settings. Is your Switch 4 On or OFF?Then use which ever column applies for the calibration ratio.
Use the formula in Application #3 to calculate the necessary new ratio.
Find the closest matching calibration in the appropriate Sw 4 column.
While the green or red is flashing, the up and down buttons change the coarse or fine setting.
Read the instructions on page 2 until you understand how this works. You'll "get it" pretty quick. If I did, anyone can. Cheers.
Page 2 of the .pdf has the instructions for observing and changing the coarse and fine calibrations. Coarse is the UP button. RED LED flashes the Coarse setting. Fine is DOWN button. GREEN flashes the fine setting.
Now I just have to figure out why my odometer isn't turning...
I had all kinds of problems with my Intelliteonix speedo in my 84 right after my 4L80e swap. I was splitting the VSS signal to the ECU and to the speedo. Sometimes it would just drop the signal. This is common when splitting a two wire hall effect signal. So I installed front steering knuckles from an 87. That gave me a spot to install a wheel speed sensor. I just used an off the shelf high speed inductive proximity switch to see the tone ring on the wheel bearing. It works pretty well now. No more dropped signal. And the speedometer works great.
