AC wont blow cold air
EDIT: I just noticed the time you posted this. Now it makes sense. A little to much of that "sippin' whiskey" is it?
You obviously have no clue whatsoever why I asked him to post the picture of the label. Let's put our thinking caps on now with the tassle instead of our Bubba hat.
Regarding "overcharge". My experience has been that R134 is more susceptible to 'lack of cooling performance' from overcharge than R12 ever was. Particularly as ambient temperature rises. Industry practice, or at least what I've seen published in various places is to use 90% of the R-12 charge amount when 'converting' to R134. The C4 system specifies 2-1/2 pounds of R12 which is 40 Ounces. 90% of 40 is 36. R134 comes in 12 ounce cans. So exactly 3 cans is the desired charge for R134 in a C4 system.
I return the control of this thread back to arbee.
Dogs - You are 100% correct in that the "low freon" code has no way of knowing what the charge in the system is. Cycling switch controls the compressor,
the high safety switch guards against overpressure and the fan switch controls cooling fans. As you stated, other variables other than low refrigerant can trigger this code.
I have done a zillion r12 to R134. My observations have been that cooling performance in our South Western desert climates where ambients regularly exceed 100F, in 'converted' systems' can be lackluster. Just the way I do it, but I continue to use the white orifice tubes that were used in the R12 system.
My question is simple: Would changing to a smaller orifice than was used with R12 result in lower evaporator temperatures (lower pressure after the orifice) because the increase in efficiency requires less refrigerant through the orifice? I realize that the 'lowest temp' possible is just above icing which must be avoided.
I drive to my place in AZ in July in 115+ F temps. The clutch isn't cycling, and vent outlet temps are in the high 40 - low 50s F. I don't sweat, but it isn't very cold in these ambients. Under these conditions, would a smaller orifice result in cooler vent temps? EDIT/ADD: Although I religiously adhere to, and achieve, the 36oz charge, could the high outlet temps be a result of an 'overcharge' in these elevated ambients? Perhaps just a bit less refrigerant charge would result in an improvement in the 115F desert?
Thanks again.
EDIT/ADD II: I found this chart of orifice tubes. I only see the white .072 for GM. There are other sizes that look like they may work, but the index nu bs are different than the white one. There may not be an alternative. Cheers
Thanks again.
My reasoning was bigger orifice = more flow and thus more heat transfer everywhere in the system with supporting air flow on the condenser. I've heard of people resizing orifices for conditions like taxi service where they are stop and go to improve performance... but I agree in that I can't really see it making a huge difference as the transfer across the condenser is going to be the limiting factor due to low air flow...
I used the stock sized white orifice when I converted my 84 to R-134a, but I did install a parallel flow condenser. I do feel that helped compared to the stock tube and fin condenser it would've had otherwise...
Edit: I was curious so I pulled my invoice from 5 years ago. At the time the condenser was $78. Cheaper enough I would just replace it. I looked up the same model, $250. Insane what prices have gone to.
