New C4 owner issues
I think there is a missing comma. "we have replaced the pump, [fuel] filter and regulator."
To the OP: Your description of the original symptoms indicate loss of power to the fuel pump. In a 1988 you can power the pump by introducing 12V into cavity G of the diagnostic connector under the dash. The pump should run and build pressure. If it does not run, check for 12V at the connector at the tank connector. One possibility that can be overlooked during a pump renewal is the pass-through connector at the top of the tank where the internal harness connects. Occasionally the gray wire (pump power) terminals become cooked and resistive.
Arbee is right. Diagnosis before guessing saves time, money, and frustration. Cheers.
F-E-D-C-B-A
G-H-J-K-L-M
1 - So, you've changed the fuel pump, fuel filter, and the fuel pressure regulator... correct?
2 - What fuel pressure did your gauge read at the Schrader valve? If I'm not mistaken (I have an 84, so mine is different), you should be getting like 42 PSI at the Shrader valve. Can you verify that you are getting that?
3 - Are you getting a check engine light? ... and if yes, did you check the codes?
> Could the jumper hose between the pump and metal line have blown off or split? You can check by listening at the fuel filler with the cap removed, have someone cycle the key. You shouldn't hear anything other than the hum of the pump. If you hear liquid splashing or sloshing, something is wrong.
> I've also seen new pumps have a leak at the pressure relief valve on the top of the pump. This squirts fuel everywhere, and results in a loss of performance. You should be able to see/hear this too.
Yes I have
I am getting 43 when I checked
this is my first project Car I have had I’ve mainly just been doing general maintenance on my last two so I’m not crazy knowledgeable about a lot of stuff.
1988 C4 Corvette - L98 Engine (Tuned Port Injection... e.g., MPFI for those of us who are less automotively affluent)
- Fuel Pump Replaced
- Fuel Filter Replaced
- Fuel Pressure Regulator Replaced
- Getting 43 PSI at the Schrader Valve
Ok, so from my standpoint... you've confirmed the pump is good, the filter and regulator are now replaced, and you confirm 43 PSI on the Schrader valve... which is actually ON the fuel rails. So there's a discrepancy here, because I'm not really sure you would be able to tell that there's no fuel going to the rails because if you see 43 PSI on the Schrader valve... the rails HAVE 43 PSI going to the injectors.
I think you now have a secondary problem (this DOES happen). Remember that fuel, air, and spark (and timing + compression) are required for an engine to move. You have air, and you are trying to determine whether or not you have fuel or spark.
First thing I would do, is get a can of "starting fluid." I would crack the throttle body on the TPI (remove the air cleaner assembly) and I would spray some starting fluid into it... a healthy amount. I would then get someone to crank the car while you begin spraying starting fluid into the intake. If the car runs (albeit bad), then you DO in fact have a fuel issue. But if the car doesn't run at all, like... doesn't even TRY to start... just cranks without any sign of combustion, then you have a SPARK problem.
Your TPI engine is basically a Multi-Port Fuel Injection system. Aside from some fancy runners, it's basically the exact same fuel system that all performance-minded GM cars had in the mid-80s. There are TWO banks of injectors, meaning they fire in batch. The left side fires, then the right side fires... and as the valves open, it allows the puddled fuel to kind of get sucked in. Each side has a separate fuse (you'll have to check the manual), but for the injectors to not fire (while confirming that the fuel pump IS good), you'd need one of three things: either both injector fuses to be bad, or the computer's ECM to be bad or not getting power.
My suspicion is that you actually have an ignition problem. You can test this by removing a spark plug, and grounding it out somewhere while it's plugged into a spark plug wire... and then have someone crank it and see if you see any spark (don't hold it... just have it clamped to something grounded on the car). If you are not seeing a spark, then you're not getting spark.
A very common problem with mid-80s GM ignitions stems from what's called the "Ignition Control Module." These can and do just fail all of a sudden... and I have literally had one fail within days after replacing a fuel pump in a Fiero. It's unrelated of course, but it happens. This ICM is not to be confused with the Electronic Spark Control Module (which is totally different). The ICM sits INSIDE the distributor. You remove the distributor cap, and under the rotor you'll see a black module with two plugs (externally to the distributor) plugged into it. It looks like this: 1988 Chevrolet Corvette Ignition Module, 8 Cyl 5.7L 19179581 by AC Delco®
If it's bad, you would need to replace it with a new one, but I recommend going with an actual GM one because the aftermarket ones fail easily. You would use THERMAL PASTE on it, between the ICM's metal bottom and the distributor's body. That helps transfer the heat. It's the same stuff computer nerds use between a heatsink and a processor when they assemble computers from parts they buy online.
Another possible failure, though less common, is the ignition coil... but my bet is on the Ignition control module...
Go ahead and do the starting fluid test first... and let me know what you see... if you get no hint of starting... like it just cranks and that's it... then you're not getting spark and it's not a fuel problem.
Here is the ALDL connector:
This is actually for a Pontiac Fiero, but it's the exact same thing in your Corvette... just verify that it's not upside down or something... you'll be able to tell since it should have the same leads. The single lead up there in the right (or by itself in whatever orientation your ALDL connector is), is directly for the fuel pump. You can run a positive battery cable to it (NOT THE GROUND) and it will automatically run the fuel pump regardless of anything else going on with your car. So you should get full fuel pressure, and it will tell you if your fuel pump is OK. If it runs fine with this... then your relay or something else is bad.
It's kind of hard to follow... we don't really know what you're checking unless you're very specific when you tell us. When you had the fuel pump out, did you test it to see if it works by directly connecting it to 12 volts and seeing if it jumps off the table? (Be careful with this, because if it still has fuel in it, it could cause a small fire).
Basically... you'll need to work from back to front, to try to determine where your problem is. There's also a relay for the fuel pump, a fuse, etc... but you said you checked all those. So at this point... hook up leads directly to the fuel pump and see if it works. You can do this directly from the pigtail under the fuel filler. If you don't hear it run, then the fuel pump is either bad, or the pump isn't hooked up right inside the tank. If the fuel pump is good then move forward... but you haven't told us if the fuel pump is good, for example... or what the result of the ALDL lead test was...
