1992 C4 Low Pressure Switch for conversion
A 1992 Clutch Cycling Switch is adjustable. Remove the connector, there is a screw between the terminals. This is the adjustment. (My experience has been that 1/8 turn CCW is about right for R-134, if it was adjusted correctly for R-12 in the first place.)
Code 09 is Low Refrigerant Charge. Go to the store and purchase one can (12 oz) of
Both of the above suggestions ignore "the right way to do it", but should give you satisfactory A/C performance that a "shop" and living in an area where choices for qualified service people are limited.
Code 09 is Low Refrigerant Charge. Go to the store and purchase one can (12 oz) of R-12 and the do-it-yourself charging hose. Jumper the cycling switch so the compressor runs continuously and put the can in the system. That should solve the 09's.
EDIT: Looking at the schematic, grounding it would not cause any havoc because the terminals are at ground potential. However, grounding wire 67 wouldn't have done jack because that would just create a circular ground circuit.
Damn good analogy on using regular fuel and premium!!! That makes perfect sense.
Get enough refrigerant in it where it doesn't set 09, and you should be ok.
There is another possibility for the Code 09. The shop may have put the 'correct' amount of refrigerant in it. But there is a leak they didn't catch, and after a period of time the system is low again and the 09 returns.
On a "conversion" that has a leak the very first place I look and evaluate are the retro-fit line charge fittings. The interface to the original nipple, and the fitting itself. Run you finger around the base of the charge fitting where it is screwed onto the original fitting. If you find it 'oily' that's a leak. Remove the red and blue caps. (If one hisses when you remove it, the schrader is really leaking.) Wet your finger (or use dish soap) and place your finger over the recess and watch for bubbles.
If the fitting is leaking at the interface to the original, its fussy to fix because the retro-fit fittings are one-way. They go on, byut they don't come off without destroying the threads on the original fitting. The low side on the accumulator isn't too big a deal to fix by replacing the accumulator. The high side line is, because they don't make the high side lines any more. (I don't install the high side retro fit fitting as it doesn't do anything. There isn't a a schrader valve in the original high side fitting. Why cause a leak where there's no reason to install the fitting in the first place?)
