Build List
Old May 5, 2025 | 07:16 PM
Essayons1028's Avatar
Essayons1028
2nd Gear
Default Build List
Sorry if this is not the right thread for this post. Im looking for recommendations on this build list any help is appreciated. TIA.
This is my current build list any recommendations? Or if I've missed anything, pushrods are not on the list yet, I'm ordering a length checker before I order pushrods.
stock 128 heads
stock crank .10 under
l98 2 bolt main bored .30 over
Xtreme Energy Computer Controlled 206/212 Hydraulic Roller Cam and Lifter Kit OE Roller SBC from comp cams
Advertised Intake Duration
258
Advertised Exhaust Duration
264
Intake Duration at .050 Inch Lift
206
Exhaust Duration .050 Inch Lift
212
Intake Valve Lift
0.48
Exhaust Valve Lift
0.488
Lobe Separation
112
Lifter Style
Hydraulic Roller
ARP bolt kits
Summit Racing 08-0019 - Summit Racing™ Timing Chain and Gear Set Pro Packs
fel pro gaskets
CA Power Steering Pumps for 1984-1991 CORVETTE - 59768
Moroso 73607 - Moroso Ultra 40 Race Ignition Wire Sets
Perfection OE Replacement 153-Tooth Flywheel 50-6527
Scorpion Racing Products SCP1000 - Scorpion Race Series Rocker Arms
Summit Racing SES-3-60-08-001 - Summit Racing™ Oil Pump and Pickup Kits
Summit Racing™ OE-Style SBC Harmonic Damper SUM-161350
Summit Racing™ Performance SBC Connecting Rods SUM-180371B
KB 9902HCKTM.030 - KB Performance Claimer Piston and Ring Kits
sniper 2 EFI on Edelbrock 2 plane
Stock 700r4 transmission
Old May 7, 2025 | 08:26 PM
mike1111's Avatar
mike1111
stock 128 heads
258
264
206
212
Intake Valve Lift
0.48
Exhaust Valve Lift
0.488
Lobe Separation
112
Lifter Style
Hydraulic Roller
ARP bolt kits
fel pro gaskets
consider modern heads. I don't have first hand knowledge, this doesn't sound right, but i read 128 heads only flow 110 cfm on exhaust side. Worth checking out.
