Rebuilding Blend Door Actuator?
Old May 6, 2025 | 03:04 PM
alexandertheok's Avatar
alexandertheok
Cruising
Default Rebuilding Blend Door Actuator?
Has anyone ever repaired the blend door actuator? Admittedly, I own a 86 berlinetta camaro, but it uses the same blend door design as the vettes.
I can hear the motor spinning but the linkage doesn’t move, I’m assuming the gears inside are toast.
Old May 6, 2025 | 06:54 PM
RWDsmoke's Avatar
RWDsmoke
Not likely to happen. Once the plastic gears inside break there are no replacements available.
Old May 6, 2025 | 10:17 PM
jdjenk's Avatar
jdjenk
Doesnt mean you cant be inventive and make some with a 3d printer or something
Old May 9, 2025 | 03:51 PM
Polo Vert's Avatar
Polo Vert
You would have to have good gears in the first place to scan so you could print them.
Old May 9, 2025 | 04:04 PM
2011KLR's Avatar
2011KLR
Im not a 3d artist, but id imagine if you have 50.1% of a gear you could mirror the other half.
To Rebuilding Blend Door Actuator?
