Brake Calipers
Old Feb 12, 2003 | 10:03 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Brake Calipers
Do 96 GS calipers bolt right in to all 91-96 ? I was considering the C5 upgrade but the price for the adapters is ridiculous, almost thuggery!
Old Feb 12, 2003 | 10:16 PM
bogus's Avatar
bogus
Default Re: Brake Calipers (GusBustamanteJr)
yes.
do you have the J55 option? (13" rotors)
if not, I would consider that, too. but you would need new brackets.
Old Feb 12, 2003 | 10:32 PM
GusBustamanteJr
Default Re: Brake Calipers (bogus)
Not sure if I do, was it available on the 91's?
So I can run the GS calipers with my stock rotors also right?
Old Feb 12, 2003 | 10:57 PM
sraft's Avatar
sraft
If you have 13" diameter front rotors, then you have the J55 (HD brakes), and the GS calipers will bolt right up. BTW, If you already have the J55 brakes then the switch to GS calipers will be a marginal (if any) improvement in stopping power.
Old Feb 12, 2003 | 11:17 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Brake Calipers (sraft)
I agree, if you have the J55 you already have the 13 inch rotors. There is the idea that the GS caliper is of a stiffer design than the standard 13 inch caliper. I would guess that you wouldn't see a diff though. If you don't have J55, you will need the rotors, caliper brakets, and calipers. Also make sure you brake lines are long enough, some people run into problems with the stock 12 inch brake hoses..
Old Feb 12, 2003 | 11:20 PM
JasonL's Avatar
JasonL
http://www.superchevyperformance.com/misc/gsbrakes.asp
Old Feb 12, 2003 | 11:28 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Brake Calipers (JasonL)
I'd still go to the C5 brakes. Its worth the extra $200. Rotors are cheaper for the C5 and the braking power is definitely superior. :thumbs:
Old Feb 13, 2003 | 01:41 AM
vetracer's Avatar
vetracer
Default Re: Brake Calipers (Ruby6spd)
I have the baer 13" slotted rotors with the later 2-piston calipers on my street driven '86 but I have no idea what the calipers came off of. How do you tell the difference between GS and the other 2-piston calipers?
Old Feb 13, 2003 | 01:49 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Brake Calipers (vetracer)
Easiest way to tell the difference between the standard J55 calipers and the GS calipers is that the J55's are unfinished aluminum, and the GS's are painted black.
Old Feb 13, 2003 | 04:05 PM
NavyVet's Avatar
NavyVet
Default Re: Brake Calipers (CorvetteZ51Racer)
The "GS" calipers were factory on both the GS and the CE in 96. Front & rear are black, and they have the word "Corvette" in silver. They take the same pads as the regular J55 aluminum calipers. Some say they are stiffer, and some say the aluminum J55 calipers with more & thinner fins cool better. Only the shadow knows..... :flag
To Brake Calipers
