ABS for my 85
Old Feb 12, 2003 | 10:18 PM
MonsterVette's Avatar
MonsterVette
Default ABS for my 85
Is it possible to install the ABS system off of an 86 or 87 on my 85? :confused:
Old Feb 12, 2003 | 10:30 PM
2manyC4s's Avatar
2manyC4s
Default Re: ABS for my 85 (MonsterVette)
I've done it, but I also installed 88+ suspensions with the abs knuckles.
Old Feb 12, 2003 | 10:53 PM
MonsterVette
Default Re: ABS for my 85 (2manyC4s)
Will I have to do that too.
Old Feb 13, 2003 | 05:06 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You need this for the wheel speed sensors.. right?
Old Feb 13, 2003 | 08:11 AM
2manyC4s's Avatar
2manyC4s
Default Re: ABS for my 85 (CentralCoaster)
To do this with your 85 suspension, you can either swap to 86-87 front knuckles(drilled for the abs sensors) or have machine shop drill yours, and then use 86-89 front bearing hubs(have abs reluctors). In back, you'll need 86-87 spindles(with reluctors) and either 86-87 spindle supports(knuckles) or have mach. shop drill yours. Drilling your pieces is cheapest but you'll need the proper pieces to show the shop where to drill.
The above parts used are ~ $650 plus shipping.
:cheers:
Old Feb 13, 2003 | 10:22 AM
MonsterVette
2MaNYC4s, You must have lots of parts! I'm gonna try the car without the ABS and see how I do. I might take on this project. What about the CPU or ECM that handles the processing? :confused:
Old Feb 13, 2003 | 02:10 PM
MrNuke's Avatar
MrNuke
I don't see it being worth to convert a non ABS car.
Lots of things could go wrong. I wouldn't rely my life on such a conversion personally.. :(
Old Feb 13, 2003 | 02:17 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: ABS for my 85 (MrNuke)
I've owned my car for 3 years and the ABS has never worked. I wouldn't bother trying to retrofit it. I thought I heard somewhere that the controller that fits into the cargo compartment behind the driver's seat is like $800 if you can find a used one.
To ABS for my 85
