CNC'ed LT4 Heads are Here!
Old Feb 13, 2003 | 12:26 AM
No Go's Avatar
No Go
Default CNC'ed LT4 Heads are Here!
Just received my CNC'ed LT4 heads back from CNC Cylinder Heads.
They look too good to bolt onto an engine...all covered up...
Will be interesting to see what the chassis dyno says for the results!
:D
Old Feb 13, 2003 | 12:34 AM
Shriker's Avatar
Shriker
Default Re: CNC'ed LT4 Heads are Here! (No Go)
Look good , No Go......did you get any flow sheets with them by any chance, just curious? Let us know some dyno results...... I am guessing 25+ rwhp gain from them alone....... :seeya
Old Feb 13, 2003 | 12:41 AM
No Go's Avatar
No Go
Default Re: CNC'ed LT4 Heads are Here! (Shriker)
Negative flow sheets...:(
Went all the way (Stage III), so hope for a bit more than 25...but you never know...kind of exciting-wish it wasn't 20 degrees in the garage!!!
Old Feb 13, 2003 | 12:56 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Very nice.......let us know how they do. :yesnod:
Old Feb 13, 2003 | 01:34 AM
Ramanstud's Avatar
Ramanstud
preetttttyyyyy....
:thumbs:
Old Feb 13, 2003 | 04:05 AM
Darkness's Avatar
Darkness
Default Re: CNC'ed LT4 Heads are Here! (Ramanstud)
How much do they charge for the stageII??? :cool:
Old Feb 13, 2003 | 06:43 AM
ericcer's Avatar
ericcer
Default Re: CNC'ed LT4 Heads are Here! (Darkness)
They did the intake, right? They told me intake alone is worth 10 rwhp.
Old Feb 13, 2003 | 08:30 AM
No Go's Avatar
No Go
I'm unsure of the cost for Stage II. This Stage III was not inexpensive, but within reason since these are my original castings off my car.
I did have the intake manifold machined as well. Not sure if they will machine LT4 heads without an intake as they blueprint the intake mating surface/etc.
I'm hoping for something closer to 350 RWHP, only changes would be a bump in compression (11 to 1), new 255 fuel pump, and LT1 Edit. But that number is probably on the optimistic side :) I can dream can't I :D
Old Feb 13, 2003 | 09:25 AM
Zix's Avatar
Zix
What cam are tou running?
Old Feb 13, 2003 | 09:54 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Ditto...
Old Feb 13, 2003 | 10:36 AM
Hurricane_777's Avatar
Hurricane_777
Are you running on a Mustang dyno? :confused:
Old Feb 13, 2003 | 10:51 AM
LT4POWR's Avatar
LT4POWR
:cheers: They look good. No flow #s :nono: If it was me I'd have the flow #s done by someone. You shouldn't have any problem getting 350 rwhp with your combo.
Old Feb 13, 2003 | 12:26 PM
91tpi-zf's Avatar
91tpi-zf
Definately get them to send you the flow sheets. That way, you will know the potential of the heads, and it will help if you ever want to sell them.
Good luck reaching your goals.
Old Feb 13, 2003 | 12:35 PM
fullboogie
Default Re: CNC'ed LT4 Heads are Here! (91tpi-zf)
What did they charge you for the porting???
Old Feb 13, 2003 | 01:07 PM
92TripleBlack's Avatar
92TripleBlack
Nice!
:iagree:
Old Feb 13, 2003 | 01:13 PM
STL94LT1's Avatar
STL94LT1
No Go,
I have been running my CNC Cylinder Head's stage 3 LT1 heads for about two months now and love them.
What camshaft did you end up chosing?
[Modified by STL94LT1, 9:52 PM 2/13/2003]
Old Feb 13, 2003 | 04:49 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Yeah how much was the stage III? i am planning on doing the same setup with hotcam this spring.
To CNC'ed LT4 Heads are Here!
Old Feb 13, 2003 | 06:22 PM
95vettski's Avatar
95vettski
They look great!
What are you doing for headers? You'll need a set of long tubes to see maximum gains from your combo.
:cheers:
Old Feb 13, 2003 | 07:51 PM
cprgmr's Avatar
cprgmr
:cool: :cheers: You're gonna fly with those heads (provided you get the cam selection right)! I wanted to do the LT4 top end too, but with today's economy, $3,300.00 for just heads and intake was a little excessive. :eek:
Old Feb 13, 2003 | 11:15 PM
No Go's Avatar
No Go
Default Re: CNC'ed LT4 Heads are Here! (fullboogie)
This will open up a can of worms...:)
I paid $2200 for the whole enchilada. That includes REV SS valves, dual springs to .620 lift, 10 degree locks, titanium retainers, full CNC to intake/exhaust/combustion chambers, stock type seals, deck was angle milled back to stock CC (~55), intake surface corrected for angle milling/blueprint and finally all bolt bosses spot faced again for angle milling.
Full CNC porting of the LT4 intake was included.
The springs were set up for my current camshaft, HOT cam, so really the only change in power producing items will be the heads/intake/LT1 Edit. I use a Mustang 1750 chassis dyno so reason I get relatively conservative numbers (compared to a Dyno Jet-notice my stock reading was only 260 RWHP), but I use the same dyno for all the runs...same operator, same 300 rpm/sec rate, same gear, etc.
I'm still running the stock exhaust manifolds.
Flow sheets were not part of the agreement-CNC does not offer this on a regular basis. I chose to have the castings flowed prior to and after the process by a third party. Numbers are improved. Gained 50 cfm on intake-surprised at that, exhaust was moderately improved, but improved nonetheless. I'm no expert on fluid dynamics so not going to jump to conclusions...will be letting the chassis dyno do that.
CNC did stamp the heads, so I think legitamacy (resale value-although I will never be selling this car-bet no one ever heard that before!) won't be in question. Heck, reputation was the main reason I went with this outfit as they are one of the original CNCers and I know I would get a product that was the same as best friend joe did...
Stay tuned... :D
