New and need some help
Old May 15, 2025 | 10:01 PM
Jtkova's Avatar
Jtkova
1st Gear
Default New and need some help
I recently acquired a 94 Corvette ...bare block with casting number 10125327...I'm needing to know what what crankshaft I need to use....I've read conflicting info on stroke length..any help would be greatly appreciated
Old May 27, 2025 | 02:54 PM
1988C4Owner's Avatar
1988C4Owner
If it's still the LT1 block, then a 3.48" stroke LT1 crank should work. If it's a gen 1 350 then you could run really any stroke you want for your displacement needs but stock should be that 3.48" stroke. Just make sure you get one for your gen small block.
