85 cranks but will not start
Old Feb 13, 2003 | 11:58 AM
85redvette's Avatar
85redvette
Cruising
Default 85 cranks but will not start
my 85 will crank but not start, I went out to move it when I started it the car started fine then died but started right back up, then later that day I went to drive it and it will crank but not start, it trys an will run for a second at times after it sits a while. I installed a new fuel pump has 39 psi at the rail and checked spark at the wires with the old screw driver trick and had spark. any one have this problem before.
Old Feb 13, 2003 | 12:24 PM
jfb's Avatar
jfb
Default Re: 85 cranks but will not start (85redvette)
Put a low power 12v lamp across one of the injector plugs and observe if it pulses when you crank the engine.
Old Feb 13, 2003 | 12:48 PM
85redvette's Avatar
85redvette
Cruising
will check them and if they don't is that the ecm
Old Feb 14, 2003 | 12:41 AM
jfb's Avatar
jfb
It could be the ECM, but first check both inj fuses. The ECM won't pulse the injectors if it doesn't receive timing pulses from the distributor.
Old Feb 14, 2003 | 08:40 PM
jburnett's Avatar
jburnett
Default Re: 85 cranks but will not start (jfb)
Make sure the fuel pump is getting the signal from the oil pressure sensor... The ECM will not activate the fuel pump relay if the sensor is malfunctioning or not seeing oil pressure upon cranking...
Old Feb 14, 2003 | 08:47 PM
Paul in Warren's Avatar
Paul in Warren
Being an ASE Master Recertified Tech / Advanced Driveability Specialist, the first thing I would say is "remember the basics" = you need 3 things to light an engine:
-compression
-fuel
-ignition
That being said - which is missing? Next time it acts up, check this:
Hit it with some carb clean spray or ether - does it light and die? If so you have a fuel issue of various sorts.
If it is unresponsive to "artificial fuel supply", take a very close look at the ignition system - just because it will spark with the ol' screw driver trick, doesn't mean it is actually getting spark in a pressurized cylinder. I have been "burned" by this a couple of times! As the pressure level increases in a combustion chamber, so does firing resistance = check for a burned through rotor arcing to the distibutor shaft and such... :banghead:
Old Feb 15, 2003 | 10:16 PM
85redvette's Avatar
85redvette
Cruising
Default Re: 85 cranks but will not start (Hydratech Braking)
Thanks for the inputs, I have checked the basics. the plugs are getting wet from fuel and I tried spraying the carb cleaner to see if it would run on it with no luck. that puts me back to the spark, going to replace rotor car and coil and hope for the best
Old Feb 15, 2003 | 10:28 PM
Paul in Warren
Once a spark plug becomes completely fuel soaked, it will not fire correctly. Make sure you also install a fresh set of spark plugs... :banghead:
Also, if it has flooded very badly, you may also want to change the engine oil as it may have become extremely fuel diluted and may not lubricate correctly...
[Modified by Hydratech Braking, 3:30 AM 2/16/2003]
Old Feb 16, 2003 | 07:51 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: 85 cranks but will not start (jburnett)
Can you tell me where you came by this information?
Old Feb 16, 2003 | 09:06 AM
Jack Boelte's Avatar
Jack Boelte
If you're not getting any spark, I would inspect the cap and rotor, and I would check out the coil with a multi-meter, if that all checks good, I would have the ignition module checked (Autozone will do it for free, but I've heard bad things about their quality; although mine has been running ok for about a year.) I'm pretty sure that the 85's ignition system is still pretty simple, like not too much input from the computer. If you have the ignition on, you should have power to the distributor and it should spark if everything inside it is working.
Old Feb 16, 2003 | 10:16 AM
jfb's Avatar
jfb
Default Re: 85 cranks but will not start (Ray Quayle)
The fuel pump circuit is in the electrical diagnosis service manual supplement.
When you crank your engine the ECM turns on the fuel pump for 2 seconds and if the engine catches, an oil pressure switch supplies power to the fuel pump.
Old Feb 17, 2003 | 01:47 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
jfb, Maybe I pick too many nits. ;) What he said was "Make sure the fuel pump is getting the signal from the oil pressure sensor... The ECM will not activate the fuel pump relay if the sensor is malfunctioning or not seeing oil pressure upon cranking...", the ECM will activate the fuel pump relay if the sensor is not seeing oil pressure upon cranking. The ECM actually activates the fuel pump relay for 2 seconds if there is no crank and continuously while cranking (receiving distributor reference pulses). I didn't want it to sound like I didn't think the problem could be the oil pressure switch, it's just that jburnett's statement was a little misleading. Just wanted to check the source.
Old Feb 22, 2003 | 08:09 PM
85redvette's Avatar
85redvette
Cruising
Update, I changed out the coil the car will start now but have to hold the pedal 1/2 way down to keep it running, it back fires a bit through the exhaust.
:banghead:
To 85 cranks but will not start
