Got a question about window washing fluid...
Old Feb 13, 2003 | 12:08 PM
87vette's Avatar
87vette
Default Got a question about window washing fluid...
My wipers work fine and there is window washing fluid in the resevoir but nothing is spurting out. How do I go about fixing the problem ?
Old Feb 13, 2003 | 12:22 PM
jfb's Avatar
jfb
Default Re: Got a question about window washing fluid... (87vette)
The nozzles on the wipers may be clogged or the flexible tubing on the nozzels are off or split. Last but not least, the washer pump may not be working.
Old Feb 13, 2003 | 02:06 PM
pascualjr's Avatar
pascualjr
Suggest that you disconnect the main hose coming from the washer fluid reservoir and check if fluid comes out of hose when pressing washer switch. (You can also hear pump running if it works.) If no fluid comes out and pump is running, the intake is clogged. I guess after all those years, gunk builds up inside the reservoir. You'll need to remove the washer resevoir and backflush and thoroughly wash it out. I just did it to my '89 when it stopped squirting abruptly. :cool:
Old Feb 13, 2003 | 05:05 PM
87vette's Avatar
87vette
Default Re: Got a question about window washing fluid... (pascualjr)
Hmmm I will take a look at it this weekend. How big of a job is it though ?
Old Feb 13, 2003 | 07:42 PM
jsquared94's Avatar
jsquared94
I see you're in Rochester... pretty darn close to me. With the winter we're having, if this car is your daily driver right now and the wiper fluid just stopped working, I would guess the hoses are frozen. Fill your resevoir (or however you spell it) with boiling water, and pour boiling water over the washer hoses a few times also. The washer fluid on my daily driver mazda hasn't squirted for nearly two months now! One day it warmed up to above freezing, and it worked! But only for a day.... :crazy: Oh, after they successfully thaw with the water (if that was the problem) I would remove the water from the resivoir with a turkey baster and replacec with washer fluid so it doesn't ice again. Good luck!
jsquared94
[Modified by jsquared94, 7:43 PM 2/13/2003]
Old Feb 13, 2003 | 07:53 PM
JCAIRE2's Avatar
JCAIRE2
Took me about 15mins of actual work to change the washer pump in my '88. The other 45mins was trying to find enough extensions to reach the bottom of the washer tank. The pump is threaded, and slips into the tank where it's secured by the nut. Easy job. Just takes some finagling :cheers:
Old Feb 13, 2003 | 10:29 PM
87vette's Avatar
87vette
Default Re: Got a question about window washing fluid... (jsquared94)
Actually no its not my daily driver. I drive a 97 Blazer most of the time now. Last time I driven the Vette was back in July of 02. However we just had a baby girl 4 weeks ago so it looks like I will only be driving the Vette on my own time such as going to the store to get diapers or just for a weekend thing :( But on the plus side it'll keep the wear and tear off the car. :)
Old Feb 13, 2003 | 10:39 PM
jsquared94's Avatar
jsquared94
In that case, disregard my previous post! ;)
jsquared94
Old Feb 14, 2003 | 05:27 PM
87vette's Avatar
87vette
Default Re: Got a question about window washing fluid... (JCAIRE2)
Lets say it is the washer pump.. where can I go about getting another one to replace it ? Would it have to be at the GM dealer ?? , and how much would a new cost since you say you replaced yours ?
Old Feb 14, 2003 | 09:08 PM
JCAIRE2's Avatar
JCAIRE2
I ordered mine from the corvette mall, but I'm pretty sure you can get them at autozone etc.. It was ~20 shipped.
Good luck
Old Feb 15, 2003 | 10:29 AM
87vette's Avatar
87vette
Sounds like a good deal. I was afraid it would cost something of a headlight motor or power antenna motor. Its hard to find things at good prices these days. But I definitly will get it if I need to. Thanks for letting me know. :seeya
To Got a question about window washing fluid...
