Intake Manifold Questions
1. How clean do the mating surfaces have to be? I've wiped quite a bit using brake cleaner and the surfaces feel very smooth to the touch, but they aren't perfectly shiny (see pics). Could this affect sealing?
2. What is the best way to clean the intake manifold? It's completely filled with carbon.
3. Should I try and wipe out the intake ports a little bit, or just leave them be to avoid any risk of dropping debris into an open chamber?
4. While the intake is off, are there any other things that I might want to address? I've already cleaned the throttle body and EGR, and I'm sending the injectors to a shop for cleaning.
5. Any tips for sealing the front and rear? I have black Permatex RTV.
6. Is it okay to leave the intake off for a day or two if necessary? I have the ports taped closed and a towel over the valley.
