C4 Hot Start Problem
Old Jun 9, 2025 | 12:44 PM
rsried's Avatar
rsried
5th Gear
Default C4 Hot Start Problem
I have a 1992 C4 that runs great. However, if I drive it so it reaches normal operating temperature then stop, it won't start again until it cools down. Once started it runs perfect again.
I have replaced most of the electrical and electronic parts except for the ECM. I'm a fairly good mechanic and I have a background in electronics but I am stumped so I took it to the only mechanic I trust.
He spent three days on it and could not locate the issue. He did discover that when it is hot and won't start there is no spark. So, it's been on non op status for 2 years which is sad.
If anyone has any suggestions I would really appreciate your input.
Thanks,
Ray
Old Jun 9, 2025 | 12:49 PM
Elduderino's Avatar
Elduderino
Maybe fuel injectors swollen from heat nd short when fully hot?
Old Jun 9, 2025 | 12:54 PM
Rush91's Avatar
Rush91
Have you changed out the Optispark?
Old Jun 9, 2025 | 01:27 PM
Whaleman's Avatar
Whaleman
I assume you replaced the ICM which is know for this. If the mechanic spent 3 days on it did he confirm it was losing spark when hot? Dan
Old Jun 9, 2025 | 10:00 PM
rsried's Avatar
rsried
5th Gear
Thanks, I'm not certain that I changed the fuel injectors. I'll check on that.
Old Jun 9, 2025 | 10:03 PM
rsried's Avatar
rsried
5th Gear
Thank you, i did change the ICM. The mechanic verified there was no spark when it wouldn't start.. Frustrating!
Old Jun 9, 2025 | 10:05 PM
rsried's Avatar
rsried
5th Gear
I did replace the optispark with and I didn't cheap out on it so it should be okay.
Thanks!
Old Jun 9, 2025 | 10:16 PM
Whaleman's Avatar
Whaleman
The amount paid for an optispark has little to no connection with it's reliability. Dan
To C4 Hot Start Problem
