5 Month problem found!
Old Feb 14, 2003 | 07:47 AM
ericcer's Avatar
ericcer
Default 5 Month problem found!
I was having a bad idle and cutout/bucking at cruising speeds generally under 2k rpm. I spent hundreds of dollars tring to find the problem. The tool I used to find the problem was LT1 Edit. This is the best tool I have!
To make a long story short, I forced my PCM to run in open loop all the time to bypass the apparently bad O2 wiring circuit I have on the passenger side. I guess my wires were slowly melting from my headers and got bad enough to make the the O2 operate strangely. Some kind of short.
Anyway I proved tonight that the car runs great by running it at the 1/4 mile strip.
Before all the mods (only 3.91 gears) I did a 13.060 @ 106.48 with 65 degree weather. http://web.tampabay.rr.com/eac/vette...MileNoMods.jpg
After with the additional mods below I did a 12.802 @ 112.41 with 65 degree weather.
http://web.tampabay.rr.com/eac/vette/images/14Mile.jpg
My Goodyear GSC tires are pretty bad so with good ones I should get a 12.6. The mph tells me the mods did me good and what you should expect with those type of mods. In fact I did four runs and all were 12.8xx @ 112.xx
[Modified by ericcer, 7:47 AM 2/14/2003]
[Modified by ericcer, 8:48 AM 2/14/2003]
Old Feb 14, 2003 | 08:47 AM
Cardshark's Avatar
Cardshark
Default Re: 5 Month problem found! (ericcer)
The links say I'm not authorized to view the page :crazy:
Old Feb 14, 2003 | 08:49 AM
Nathan Plemons's Avatar
Nathan Plemons
So are you gonna fix the wires so it will run in closed loop the rest of the time?
ericcer's Avatar
ericcer
Default Re: 5 Month problem found! (Cardshark)
That is wierd. Try this alternate.
http://home.tampabay.rr.com/eac/vett...MileNoMods.jpg
http://home.tampabay.rr.com/eac/vette/images/14Mile.jpg
Old Feb 14, 2003 | 08:54 AM
ericcer's Avatar
ericcer
Default Re: 5 Month problem found! (Nathan Plemons)
Not anytime soon. I am tired of working on the car. Besides in open loop I have total control on the A/F ratio. I can tune to get better gas mileage too. I like the fact that the PCM is not try to "correct" my tune all the time. Running in open loop is not uncommon.
Old Feb 14, 2003 | 09:44 AM
LT4POWR's Avatar
LT4POWR
:cheers: I'm glad you finally got it fixed. I ordered LT1 edit yesterday for my little heads/cam project.
Old Feb 14, 2003 | 09:48 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Glad you found the problem :cheers:
Old Feb 14, 2003 | 12:23 PM
No Go's Avatar
No Go
What a relief that is...
I'm looking forward to working with LT1 Edit as well. Glad to hear it works in many ways...
Old Feb 14, 2003 | 01:25 PM
ncider's Avatar
ncider
Default Re: 5 Month problem found! (No Go)
Are those heads sitting on the kitchen table? Your wife is going to kill you. :lol:
Old Feb 14, 2003 | 04:34 PM
superlund's Avatar
superlund
Default Re: 5 Month problem found! (ncider)
Glad you finally found it, I know you had been fighting it for some time. :cheers:
How are the Z06/LS 28 Lb injectors working out?
Old Feb 14, 2003 | 10:39 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: 5 Month problem found! (superlund)
What product are you using to force the PCM? Are you happy with the program?
Old Feb 15, 2003 | 03:39 PM
ericcer's Avatar
ericcer
Default Re: 5 Month problem found! (ConeKLR)
The Z06 injectors seem to be working fine. I think they were the best choice for my car.
I used LT1 Edit for programming the PCM.
To 5 Month problem found!
