1993 AC Compressor issues, bearing?
Old Jun 19, 2025 | 08:48 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default 1993 AC Compressor issues, bearing?
I didn't want to keep hijacking another thread.
Basically a couple years ago replaced AC clutch, as it smoked up.
Bearing seemed fine, spun easy never heard any noise.
But, besides a slight vibration on hard pulls, I have noticed my Vette runs hotter, about 30 degrees with AC on
Both fans work, and with 160 thermostat, be cool radiator and programmed to have fans come on at 185 and 190 first/second fan respectfully
As soon as I turn it off, it cools down quickly to about 195. With AC about 215 to 220.
Is that delta normal. 95 degrees here, in light traffic and stop and go up to 50. This to just give an idea.
I listened to bearing and compressor. As best I could. Compressor is quiet whether under load and on or not. But bearing, as close as I could get stethoscope by pulley, you can kind of hear it. Under load it's more noticeable.
This is with AC on max
396 LT1, 500HP at flywheel, 2800 stall and 3.73 gears, of that makes any difference
Old Jun 20, 2025 | 12:59 AM
arbee's Avatar
arbee
If the bearing is causing (your hypothesis/question) the temps to rise, it would do it with or without the AC turned on. Without the clutch engaged, the pulley is doing no work - simply spinning on the bearing. I think you would find out pretty quickly if the bearing was leaving town. It is the clutch that is hooked to the swash plate.
Old Jun 21, 2025 | 07:48 AM
steve40th's Avatar
steve40th
Sometimes I over think this damn car, lol.
To 1993 AC Compressor issues, bearing?
