Sensor Locations L98 - Confirmation
Old Jun 23, 2025 | 03:14 PM
JL_L98's Avatar
JL_L98
Default Sensor Locations L98 - Confirmation
Have looked at the FSM, and threads here on the forum. I have sources a very nice 1991 L98 that I want to transplant in my very clean 1986 corvette. Here is my interpretation of what lives where.
Looking for a quick confirmation these are marked correctly. The original 86' motor was poorly carb converted, and the harness totally chopped by the prior owner so I had little reference to go from.
Old Jun 23, 2025 | 05:32 PM
AZSP33D's Avatar
AZSP33D
That all is correct, not sure about the oil temp sensor as I no longer have it there for the 1986, thought maybe it was on the aft side of the block behind the manifold, but you diagram is probably correct even though that's not the late 1986 OEM engine shown.
Old Jun 23, 2025 | 07:40 PM
marshallnoise's Avatar
marshallnoise
On my 87 L98, the oil pressure senders are on the back behind the distributor.
Old Jun 23, 2025 | 09:23 PM
JL_L98's Avatar
JL_L98
Goal here is to swap out the 91 sensors w/ 86 model year sensors (as needed, a few are different) so my ECU and new (to me) harness play well w/ the motor.
My harness is set up for the sending unit and pressure switch at the rear of the block.
if my diagram above in the 91 checks, I am comfortable with the rest.
thanks to those who have chimed in.
Old Jun 23, 2025 | 09:25 PM
JL_L98's Avatar
JL_L98
the engine shown is a 91' and going into my 86' chassis.
Old Jun 30, 2025 | 12:23 PM
mmallo's Avatar
mmallo
Take a good look at the fuel lines as well to ensure you are good there. I did a swap of an 86 engine into an 88 body and learned that GM changed the fuel return size, in 86 they were smaller, if I recall 5/16 tube dimension with a 16 mm fitting and in 88 it went to match the supply line which was a 3/8 tube dimension with an 18 mm fitting. That caused a bit of "fun" to get me out of the shop and home, but later ordered AN lines and the proper fittings to make it all work and look clean.
Old Jun 30, 2025 | 12:28 PM
marshallnoise
Yeah, can confirm that my 87 had the older 3/8 and 5/16 dimensions. Good call out.
Old Jun 30, 2025 | 12:54 PM
JL_L98's Avatar
JL_L98
Good callouts. The motor came w/ the fuel lines still attached. During the dropout, they disconnected the lines in the fuel filter area. Will close attention when I reinstall them that the fittings are a match under the car.
Motor is in w/ a few upgrades since I was already there.
Old Jun 30, 2025 | 04:39 PM
vader86's Avatar
vader86
Those sensor locations look correct
Old Jun 30, 2025 | 06:42 PM
JL_L98's Avatar
JL_L98
Right on, thank you!
Old Jul 4, 2025 | 01:04 AM
the blur's Avatar
the blur
86 probably wasn't D port heads..
Old Jul 4, 2025 | 07:57 AM
JL_L98's Avatar
JL_L98
correct - the original motor had cast iron heads and oval exhaust ports. The 91' motor going in it, are aluminum heads w/ D-ports ( which receive Headman Elite headers).
To Sensor Locations L98 - Confirmation
