L98 TPI MAF wireing harness
Old Jun 25, 2025 | 02:10 PM
snackstick's Avatar
snackstick
Default L98 TPI MAF wireing harness
I have just completed a engine swap with a L98 TPI using a Painless standalone wiring harness and the the computer prom chip they give is 16068654 that one is no longer available. I have two questions: 1. does anyone know someone that may have that chip. 2. does anyone know of another prom chip that will work. My problem is that the chip I am using is a 1988 stats chip. the kind I need is a 85-88 non stats chip. I'm waiting on a by pass module but the techs at painless said it may have a conflict with my computer. Any information will be appreciated
Old Jun 25, 2025 | 08:53 PM
Tunedport90's Avatar
Tunedport90
Non stats ? Do you mean vats ?
Have you tried www.tunedperformance.org
86-89 the 1227165 ecm chips interchange. Could get a stock prom for f body 87-88 if 350 or custom tune better suited to the engine .
Old Jun 25, 2025 | 08:57 PM
Tunedport90
16068654 Is a ABWN f body 350 automatic tune you can sometimes find it or abwt on eBay. But it’s setup for the 9th injector. A custom 89 based tune would probably be better.
Old Jun 26, 2025 | 10:23 AM
snackstick's Avatar
snackstick
The harness that Painless sells is for a 89-92 MAF and the chip they give is the one I listed and the one they said they know works. I ask them if there were any other ones and they told me that it was the one tested and knew works. My problem is I'm having a stats issue. code 49. I can start the engine with 45 psi fuel pressure and it runs 1or 2 seconds then dies. I can do that twice but the third time it dies and I have no fuel pressure and it won't start back until it sets awhile. I have replace the fuel pump twice. Painless tech says it is a stats issue. That is the reason I need that prom chip
Old Jun 26, 2025 | 10:26 AM
Tunedport90
a 60102 is maf 86-89 1227165 ecm, there is no code 49 with obd1 if you have a 60103 it uses a 1227730 different chip for speed density.
Old Jun 26, 2025 | 10:28 AM
Tunedport90
46 code would be for security issues vats
Old Jun 26, 2025 | 10:33 AM
Tunedport90
Without injector pulse it shouldn’t have started. Unless injectors are leaking or a ripped fpr diaphragm. What’s the broadcast letters on your computer chip ? The 3-4 letters on the silver sticker ?
Old Jun 26, 2025 | 01:41 PM
snackstick's Avatar
snackstick
I'm sorry, type o. i meant to say VATS. code 46
Old Jun 26, 2025 | 01:43 PM
snackstick's Avatar
snackstick
thats the one painless tech says
Old Jun 26, 2025 | 06:34 PM
Tunedport90
All tpi 86-91 y body has vats enabled in the chip. Can be programmed out. But sounds like you have a few issues you need to resolve.
Old Jun 26, 2025 | 07:03 PM
snackstick's Avatar
snackstick
like what
Old Jun 26, 2025 | 07:06 PM
snackstick's Avatar
snackstick
Tunedport90
It it starts and doesn’t hold fuel pressure, leaky injectors or shot fpr.
Old Jun 26, 2025 | 07:09 PM
Tunedport90
8809
what’s 8809 ?
Old Jun 26, 2025 | 07:16 PM
snackstick's Avatar
snackstick
I did email www.tunedperformance.org but I've not heard back from them
Old Jun 26, 2025 | 07:19 PM
snackstick's Avatar
snackstick
that's the only 4 I could see on the chip
are there any way to tell by the numbers what the prom came from
Old Jun 26, 2025 | 07:26 PM
Tunedport90
I found I have a ABWN and ABWT the letters are called a broadcast code. But if you have aluminum heads I’d use a ARAP with vats delete.
To L98 TPI MAF wireing harness
Old Jun 26, 2025 | 07:29 PM
Tunedport90
https://www.3rdgenformula.com/87/promcodes.htm
Old Jun 27, 2025 | 08:19 AM
snackstick's Avatar
snackstick
how would I tell if it has vats deleted?
here are 2 chips I found. 16068767 and 16035006
do you think one of these would work
Old Jun 27, 2025 | 09:41 AM
Tunedport90
I don’t know that those are acdelco calibration part numbers , where did you find them on the internet? What are there broadcast codes. All of the y body 86-89 calibrations have vats. F body 87-early 88 didn’t have vats. But if this is for a stock 88 Vette l98 you really need a chip for that engine or ARAR or ARAP vats deleted.
