1986 LS swap
Old Jun 29, 2025 | 02:38 PM
espop125's Avatar
espop125
Default 1986 LS swap
Hi everyone, I’m in the process of ls swapping a lq9 in my 1986 and have some questions and hoping someone can help. I have searched on here and google and can’t find much. I want to retain my factory digital gauges and use the harness that came with my ls out of the 2003 Escalade. What do I need to do to make factory gauges work? I did find that I can by the sensor adaptors for oil pressure , temperature sensor but do I keep my original computer in the car to send this to dash or can I make the ls harness work with it and also what do I do for tach and speedo?
Old Jun 29, 2025 | 08:39 PM
wolf_walker's Avatar
wolf_walker
Wiring diagrams are you friend. I've LS'd a few GM vehicles of this era and other than the MPG readouts I suspect you can retain the oil temp and pressure and engine temp just by physically adapting the senders and wiring them as needed.
The ecu and gauge temp senders I know off hand are separate on an early 86, the oil pressure likely is as well but they tied it into the starting circuit such that it has to see 4psi or so from one sender to trigger the fuel pump or something
along those lines. It's all pretty straight fwd in the FSM. You need the manual for the car and the manual for the doner vehicle/harness or you're going to have a headache.
Old Jun 30, 2025 | 08:58 AM
Squag27's Avatar
Squag27
I'm currently putting an LS6 into my 1986 C4 and the factory service manual is definitely your friend, bonus points if you get an actual hard copy with color wiring diagrams. Also I can confirm that the gauge cluster gauges are standalone from the ECM, So far I only have the oil pressure gauge hooked up but I also plan on running a coolant gauge probably in the upper rad hose with a coupler. Also your best bet is to either ditch the stock Escalade harness for an aftermarket one or prune it for just what's needed. Can't comment on transmission control for the car though as I'm running a T56 in mine, not an auto.
Old Jun 30, 2025 | 09:17 AM
Phobos84's Avatar
Phobos84
I swapped an LQ9 and a 4L80e in mine with a big Summit cam and TEA 243 heads. Basically making an iron block LS2 at 10.9:1 compression.
The best advice I can give you is to not use the factory gauges. I know you said you want to keep them. But it makes the swap much harder. Before you say for sure you want to keep the factory stuff take a look at some aftermarket options. Remember you can sell off the factory cluster to help offset the cost of new gauges.
The second thing I would recommend is to not use the 86 transmission. I'm assuming yours is an automatic. If it's a standard then skip this part. It's fairly easy to fit a 4L80e or a 4L60e in these cars. You just need to weld together a C beam adapter. Lots of threads here about how to make them. You just need to order a piece of 4 1/2" box steel that's around 1/4" thick. And again if you go that route you get to sell the old trans to help pay for the project.
I made a video a long time ago about how I did mine. I'll post a link. The video was back with my old Chinese gauges and the old exhaust. But you can see my other videos for updates to the car if you want.
Old Jun 30, 2025 | 09:50 AM
Squag27's Avatar
Squag27
https://youtu.be/rDLhoTz5zjc?si=tQhWtFHfqcpxmEyP
Small world, I watched this video you made last November before I decided to swap my C4. I have to disagree with you on the gauges though. They're a huge part of what makes the early C4s so cool and they're really not hard to keep. It requires pruning the factory engine bay harness instead of removing completely but I wouldn't say it was particularly difficult. Probably the biggest annoyance is figuring out where to put the gauge coolant sensor since there's no room to put it on the passenger side head.
Old Jun 30, 2025 | 09:59 AM
Phobos84's Avatar
Phobos84
Use a C6 Vette LS3 water pump. Then get ICT Billet spacers. This will give you two threaded ports for gauge sending units or a steam line.
You can put a sender on the passenger side. I think the ohm range of the LS temp sender is the same as the C4 's. I would try a LS temp sensor on the passenger side and see if it will run the gauge. If it won't you could add some resistors to the harness to get it in range.
Old Jun 30, 2025 | 11:49 AM
wolf_walker
I 2nd the not using the 700r4, 4L60 or 80 if needed is a waaaay better match to the motor and shifts a heck of a lot better too. Isn't a bad trans after a correct rebuild.
Old Jun 30, 2025 | 12:41 PM
Phobos84's Avatar
Phobos84
That and you can get a reasonably low mileage 4L80e or 60e in a local salvage yard with a warranty for around $200. So if you do ever scatter the thing you can just grab another one.
To 1986 LS swap
