Guess What I just found out about my car......!
Re: Guess What I just found out about my car......! (StealDads67)
My one skeptical thing is, Why would you only go from a 3.45 to a 3.73??? What a waste of $300 bucks, go to 4.10s :yesnod:
[Modified by StealDads67, 7:16 AM 2/15/2003]
Mike
Re: Guess What I just found out about my car......! (luvmy92)
Guys,
That program is fairly accurate, most of it is juct simple math calculations to get the Speed for your said RPM. I made that program to help me decide what gears I wanted to use when I did my 6spd conversion. It is basically for cruising RPM/ speed. I had checked it against my car when the Auto/ 3.07 was in it and also with the 6spd/ 3.45
The ratio's for the 4+3 and the ZF6 are correct. the 700r4 listed was from my 89. If you have Ratio's for a different Trans I think it is set-up for you to add them. I did that program in 1996 and re-did it in 1999 when I lost the source code and made it a bit different.
Still a better way to determine you ration is by hand turning the driveshaft and counting the tire rotations. I thought after I made that I would put it on my website for anyone to use. I also figured it was not something everyone would like. but at least it is free :D
here is the link http://www.vettextc.net/gear_program.htm
Re: Guess What I just found out about my car......! (Darkness)
is there a way to check if its an automatic?
Its quite simple, you'll have to get on all fours and look at the tranny and ask if she has 4 or 6 gears, if she says 4 its an auto if 6 its a manual, but sometimes they get moody and wont answer so better check some other way, maybe build sheet will say :thumbs:
Darkness. Your are TOO much!
Re: Guess What I just found out about my car......! (CFI-EFI)
What was the originall gearing ratio for the Rear end of an 84? I've got 3.54;s and I'm cruising at 65 in 4th at abvout 2Krpm with that gear, I wonder how fast the engine would be spinning with originall gears? Idle?
Also with 3.54's how much can I see an increase of acceleration to 60 time? The specs say 6.6 to 60 but it sure as hell doesnt fell like 6.6 :yesnod:
Re: Guess What I just found out about my car......! (93aqua)
I've heard in a 4sp auto, put the car in "D"(3rd gear), accelerate to 70 mph, the tach will read what the gear ratio is. I.E.---70 mph, tach reads 30 or 31, gear ratio = 3.0x
Re: Guess What I just found out about my car......! (CaneinBatonRouge)
I dont find that accurate because you still have to factor in your Circumfrence of the Tire. Sya 26inch OD tire travels 6.8ft per revolution. The say your in 3rd gear 1:1 and spinning at 3000rpm and you have 3.5 rear gear( All Examples) then you would be going 66.xx MPH. And then if you have 4th gear which is .7:1 ratio then you would be going 94.6x MPH at 3000rpm with tha rear gear and tire size :yesnod:
Re: Guess What I just found out about my car......! (Light84vette)
Hey Guys... Well... I didnt check by pulling the cover... for obviuos reason haha..... But the unit has been opens... you can tell by the silicon around it.... So.. I guess thats a pretty killer find if you ask me....
http://f-body.org/gears
i think you have the same trans as the LT1 camaros
:cheers:
(for you guys with autos)
[Modified by TreyZ28, 6:10 PM 2/24/2003]
:cheers:
The easiest way to tell if your vette is an automatic is to count the number of pedals. Two = automatic Three=Stick.
Sorry I was just kidding......
