Ignition Cylinder Jammed
Old Jul 6, 2025 | 01:28 AM
SmoshPosh's Avatar
SmoshPosh
7th Gear
Default Ignition Cylinder Jammed
Last night when i parked my 1994 corvette base, all was fine no problems and shut off as normal. Today though, when i put the key in, it switches to accessory and on lighting up the dash but when i try to twist it further to turn on the starter it gets jammed or something not allowing me to turn on the car. i tried on both sets of keys and still nothing which is frustrating. I would love to hear some ideas on if this is fixable hopefully without taking apart the whole steering column and if not where to get a new decent ignition cylinder that'll fit and work good, thanks ahead of time!
Old Jul 6, 2025 | 09:22 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Maybe try turning and holding the wheel a bit left or right while you're turning the key. The wheel is likely locked, but often just needs a slight movement one way or the other. That's always worked for me. This happens all of the time on cars.
Or maybe quickly move the shifter through the gears a few times and back into Park and see what happens.
