Msd opti failure or not?
Can the 6al be on the fritz, anyone know?
Use the onboard diagnostics. You're looking for Module 4, H16. If it is there, clear it, remove jumper, try to start it, recheck codes, if H16 is back, it is the opti. Pretty simple. Takes less than 60 seconds.
EDIT: Generally, if it fires it isn't the opti, because bad opti = no sparks = no sparks, won't fire. "Won't stay running" is something else. Again, what if any codes are in the onboard diagnostics? Both Module 1 and Module 4.
OP, get an opti from a local parts store and get it replaced. Probably a Cardone or other generic, and it will get you home. And might work for several thousand miles.
once im home ill get to replacing it. Not sure if ill go for my 7th optispark in 2 years or if ill switch to the ls coil on plug kit
Typically, if a starts running badly as the OP described (won't take throttle, maybe runs better when warm than when cold, gets progressively worse until it shuts down completely), the coil is the problem. The fact that one coil literally exploded on him is also an obvious clue. This is easy enough to test: when the car won't run, use a test light to see if the coil is getting an impulse to fire or use a noid light to see if the injectors are getting a signal. If they are, the then opti is fine and it's either the coil or the actual cap/rotor or plug wires. Now, as to why coils keep failing (if that's the problem)? I'm not totally sure, but if they are getting proper voltage then it probably comes down to bad quality coils. If they are getting too high a voltage, then maybe that could hurt them, but the OP already said his voltage is low, if anything.
OP, the whole coil-on-plug conversion thing seems like a huge waste of money and time, and those things also don't always work. The opti system is not nearly as bad as people tend to think, and I bet 90% of the problems that get blamed on them are actually caused by something else (been there, done that). You need to do real diagnostic work to isolate the real problem instead of just making assumptions and throwing parts at it. Here is a decent tutorial that will get you started: How To Test the GM Ignition Control Module (1995-2005). In the process of doing these checks, you'll end up determining if the opti is reading the disc inside and sending a proper signal, as well as checking the ICM and coil functions. Also, unless you're absolutely sure the plugs aren't firing when this failure happens, you should get a fuel pressure gauge and verify adequate fuel pressure.
That's awful advice. Those things are junk and I've seen people who got two in a row that were DOA: you do all the work and the car won't run at all after you've finished. Probably the best option for a new opti now is the Petris replacement. It seems to have a decent optical module. If the OP still has his OE opti, then I would encourage him to consider replacing that.
You mentioned MSD before, and I forgot. Sorry. The cap and rotor part of their is supposed to be good, but the optical sensor is not. This is the same story with most replacements, and I'm pretty sure that includes AC Delco these days. The Petris unit is the only one I know of now that uses a good sensor. FWIW, my C4 ran the same OE opti for years with many track days in very hot weather and many autocross runs (lots of heat soak) without ever missing a beat. The designs fundamentally work.
I can't rule out your PCM entirely, but it seems very unlikely that a problem would be intermittent and that replacing the opti would seemingly fix it. PCMs tend to either go bad altogether or keep running fine. When they go bad, they tend to run the fans at full speed all the time, or the amplifies inside for the injector circuits (there are two of them) just stop firing the injectors completely (and that doesn't fix itself). So I'm not betting on the PCM, although I'm not ruling it out entirely.
