Replacing multec injectors
Old Jul 18, 2025 | 06:55 AM
Roberts Dark's Avatar
Roberts Dark
Cruising
Default Replacing multec injectors
Hi. One of my multec injectors is showing only 1 ohm resistance, so I'll be changing the injectors. I have decided I will use OEM style injectors from Rockauto. More precisely the SMP FJ47 or SKP SKFJ10024. Are there any known problems with these? I dont want to buy the FIC bosch 3s as they wont be a perfect fit and my car is stock.
So, which one should I buy, SMP or SKP?
Old Jul 18, 2025 | 11:50 AM
wolf_walker's Avatar
wolf_walker
I don't believe any of the random asian reman/new injectors have especially good reputations in general.
I also question if they are identical stock replacements or only stock size/shape with more modern/cheaper guts.
I forked over $450ish for set of the Delphi stock replacements from one of the recommended vendors recently with the hope that I could
avoid having to re-tune as folks so often do when going to the newer style ones but no such luck. My fuel trims immediately went wonky.
Not so much that the system can't correct for it, least on my car, but it's obvious it's having to work at it. If I had it to do over again
I'd have my stock ones rebuilt, and if I had one or two bad ones that wouldn't clean up I'd buy original used replacements till I found some
that would.
There was remarkably little difference in how mine ran with the 40 year old 156K injectors vs the shiny new ones.
Overall it was a disappointing, expensive annoying experience.
Old Jul 18, 2025 | 01:17 PM
Tunedport90's Avatar
Tunedport90
Southbay fuel injectors sells Delphi, really great quality
Old Jul 18, 2025 | 01:25 PM
wolf_walker
See my post above....
Old Jul 18, 2025 | 01:30 PM
Tunedport90
Thanks, read your review just sharing a review. The D3 are another option but tend to run lean and very noisy. Voltage battery offsets can be used to correct fueling but the delphis are the best plug and play to replace multecs.
Old Jul 18, 2025 | 02:00 PM
wolf_walker
Interesting, the delphi are rich, barely correctable at idle and a little better at speed. I've seen it suggested that
it's because they open and close so much faster that for a given duty cycle they are passing more fuel than the ECU
expects since the old injectors are slower to do so. One may well never notice this unless they are looking for it
from the ECU data, and I'm sure one motor to another varies.
Old Jul 18, 2025 | 02:02 PM
ULTM8Z's Avatar
ULTM8Z
That's been my experience as well with Bosch-III's.... BLMs sometimes shoot up into the 150 range, which then requires tuning.
But, once properly tuned for, they're fantastic injectors. Got some from Southbay a while back and they're awesome.
For someone with a stock car who wants hassle free replacement, then yeah I hear the Delphi's are the true drop-in replacements.
Old Jul 18, 2025 | 02:08 PM
ULTM8Z's Avatar
ULTM8Z
In 8D, I know there's a "helper" table where the ECM will command a pulse width adder when the baseline commanded pulse width gets below a certain level (typically at idle).
From what I understood it's because the old Multecs weren't very efficient at low PW's, so GM put in this "helper" table for low PW's. When you upgrade to modern injectors, they don't need that "helper" table, so if you don't zero it out, you'll get potentially significantly richer mixtures. The helper table can deliver up to ~0.5 millisconds... so if your base PW is say, 1.5 ms, you could be getting a ~30% richer mixture than needed.
DA2/DA3 has this table as well. But I don't see it in 6E... doesn't mean its not there, just that my particular ECM definition file doesn't have it.
Old Jul 18, 2025 | 02:12 PM
Tunedport90
where did you see the battery voltage offsets for the Delphis ? Were you zeroing out the low pw table. Sounds way off like you had a leaking injector or something else causing the rich connection.
Old Jul 18, 2025 | 02:17 PM
wolf_walker
Makes sense. I wouldn't call them a true stock drop in replacement though, I'd call them as close as you're going to get for new injectors.
Old Jul 18, 2025 | 02:18 PM
Tunedport90
I’ve had a few instances where people used fic d3. They were actually opposite of southbays and I had to pull fuel on their tunes and zero low pw tables. Just not really a plug and play deal.
Old Jul 18, 2025 | 02:19 PM
wolf_walker
The entire point of buying the delphi's was to NOT have to look at software. I just looked at the INT and BLM before and after the swap on my scan tool.
I guess it's technically possible one is leaking but they were a matched set from Southbend so I doubt it. Not rich before, rich next day
after installing. Car runs just practically the same, been a few times I thought the crank time cold was a little long as I've seen reported
for other injectors but it's been inconsistent enough I wouldn't swear to it.
Old Jul 18, 2025 | 03:18 PM
ULTM8Z's Avatar
ULTM8Z
Hmm.... it's a shame its such a crap shoot.
Old Jul 18, 2025 | 03:23 PM
wolf_walker
Straying from the topic I guess but I think my solution is going to be that Fitech TPI replacement system.
Or the LS in the corner of the shop.
Old Jul 19, 2025 | 09:18 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I just recently uninstalled a full set of Delphi injectors and replaced them with SouthBay's Bosch III injectors.
In hindsight, I really wish I'd just replaced the one bad Delphi injector versus all 8 injectors because the Delphi ones are just better injectors, in my opinion.
These Bosch ones tick like crazy and they're very loud. Drives me bonkers. It's almost embarrassing at a red light.
Old Jul 19, 2025 | 09:40 AM
Tunedport90
The lifter tick noise is rather annoying on the D3. Great spray pattern though
Old Jul 19, 2025 | 10:11 AM
ULTM8Z's Avatar
ULTM8Z
Surprised they're so loud. With the hood closed I can barely hear mine (if at all).
To Replacing multec injectors
Old Jul 19, 2025 | 10:47 AM
wolf_walker
The delphi are just about silent I'll give em that., quieter than stock in my case. Granted that's stock with 156K on it.
Old Jul 20, 2025 | 12:57 PM
Natty C's Avatar
Natty C
Well. What compounds the matter is my OCD. It's bad.
I listen for them loud things...which makes it worse. lol.
If it wasn't for the OCD I might not hear em so much either.
Old Jul 20, 2025 | 03:06 PM
ULTM8Z's Avatar
ULTM8Z
Hah... that's me with noises on the inside of the car. Soon as I hear some squeak or something, I'm immediately going after it...
