T56 swap surprise.
Here's where things went sideways: Even after bleeding it several times over, the pedal didn't feel quite right. In the mean time work on the engine continued, there's always a hundred things that need to checked, changed, or modified. Finally I'm getting the point where I can start this critter up and get it off jack stands. PROBLEM: the clutch is NOT disengaging. My next act was to determine if the clutch fork was actually moving so whipped up a little brace, in lieu of the slave, that would hold the fork in/open. No dice - so the problem isn't the slave.
Ugh, so back out the exhaust, drive shaft, "C" beam, transmission, bellhousing to see what's going on.
As you can see my new Spec clutch is now sport a nice grind stripe. An here's the culprit. My clutch fork is hitting the pressure plate. WTF?
So I ran to the internet to see if someone had encountered a similar issue. I did find a post on the Chevelle Forum with basically the same problem and the fix. My stock F Body flywheel looked to be about 35.3 mm thick, with the Pressure Plate 42mm, total 77.3mm The Fidenza FW was 36.9mm thick, and Spec PP 43mm thick, giving me a total of 79.9 A good 2.6 mm bigger than stock. The fix was to reduce the height of the clutch pivot fulcrum. The Chevelle Forum took off 1/8" so I ground about 3mm off the bottom. I did also smooth out the ridges on the fork where contact was made, not much maybe only 1mm, so as not to weaken it.
Wrestled everything back together, crossed my fingers, and it worked. The clutch pedal feels normal and it does disengage. Now here's the caveat: I have not road tested this yet, so I don't really know where my engagement point is regarding pedal travel. With any luck it should be manageable. I'll update if this all goes to hell.
Then check your clutch pushrod throw for the master cylinder, to make sure you are getting the full stroke on the master. I had to lengthen mine about 5/8 inch to get full stroke. After that it worked beautiful. But save your custom length rod because you will need it when you replace the master. Even better if you make it adjustable.
