Testing A/C compressor
Old Jul 29, 2025 | 02:15 PM
Sfd6533's Avatar
Sfd6533
Default Testing A/C compressor
I just pulled all the a/c stuff out of a box and installed it with all new green o-rings, accumulator, oil and 12 oz of 134A. The compressor clutch never engaged. I checked the fuse and made sure it is plugged in. How can I test?
Old Jul 31, 2025 | 06:31 PM
Kevova's Avatar
Kevova
With 2 jumper wires and a 12v battery you can touch terminals of clutch and watch and hear clutch apply drive plate if you have a helper, they should be to turn plate and pulley. Beyond that it's install all the parts charge it and see what happens. If you jump cycling switch on the car, ac clutch should engage regardless of freon level. That would prove the car is capable of turning ac compressor on
Old Jul 31, 2025 | 06:42 PM
s carter's Avatar
s carter
Couple of needed things to aid in helping you,
year, standard AC or C68 automatic climate control
Old Jul 31, 2025 | 08:00 PM
Sfd6533's Avatar
Sfd6533
85 standard
Old Jul 31, 2025 | 11:45 PM
s carter's Avatar
s carter
Originally Posted by Sfd6533
85 standard
Those 2 things eliminate a lot of confusion, there's no vacuum module no sticky button and endless things that don't work with corrosion.
So things can be boiled down to does the switch in the dash function correct and you have been already looking at the pressure switch/sensors
To Testing A/C compressor
