Alignment question...
Old Feb 15, 2003 | 10:48 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Alignment question...
OK, so the outsides of my tires wore really fast. So I took it to the alignment shop, and they said I need lower ball joints. So today I replaced the lower ball joints.
It feels a bit better, but I noticed that it still shimmies a bit up front when I hit a bump. Before I did the ball joints, the alignment was pretty far off.
I'm having it aligned next week, my question is could these symptoms still be due to the bad alignment? Or do i have other problems that they missed?
Old Feb 15, 2003 | 11:52 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Alignment question... (CarAteMyMoney)
If the toe is off the tires could be scrubbing enough to cause some shimmy. But it would have to be off by a lot.
Old Feb 16, 2003 | 03:26 AM
CarAteMyMoney
Default Re: Alignment question... (Lone Ranger)
That sounds about right. Instead of the tires being straight the fronts are kind of faced in toward each other...
I guess instead of being like | | they're more like / \
well not that much but still bad, he said they're "plowing down the road"
Old Feb 16, 2003 | 09:27 PM
Z06_BluByU's Avatar
Z06_BluByU
yes, your alignment could cause this.. as well as worn shocks, out of balance tires..
Old Feb 16, 2003 | 09:44 PM
vader86's Avatar
vader86
Default Re: Alignment question... (BluByU)
Gotta have the whole thing aligned and see if the problem returns. Tie rods may be worn from the bad ball joints, out-of-balance tires. Shocks could cause it, but i wouldnt worry about that one yet.
Old Feb 16, 2003 | 10:10 PM
CarAteMyMoney
Default Re: Alignment question... (vader86)
Yeah, the shocks are new and the tires are SHOT from the ball joints, so when I put new tires on and get the alignment done i'm hoping it all goes away
To Alignment question...
