I have 92 front calipers and want to upgrade them to steel braided lines. I already have the -4 lines and need a confimation on the correct banjo fitting for this application.
I am looking at using Earls part# 997641 which is described as a -4 line size with a 10mm hole diameter. Is this the correct fitting? Can the OEM bolt be used? Is there another fitting that works that can be recommended?
