17x11 50 or 56mm offset
Old Feb 16, 2003 | 03:06 PM
korvettek's Avatar
korvettek
Default 17x11 50 or 56mm offset
most 17x11 for a 91-96 vette iv seen advertise a 50 mm offset .i found a company that advertise a 56 mm offset 17x11 ,this would allow the tire to sit 6 mm more in than the 50mm offset correct. :iagree: :thumbs:
Old Feb 16, 2003 | 03:18 PM
95wht6spd's Avatar
95wht6spd
Default Re: 17x11 50 or 56mm offset (korvettek)
The 56mm is the GS offset and should be used on 91-96. The 50mm is the ZR1 offset for earlier cars because they are narrower under the body.
Old Feb 16, 2003 | 03:31 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Default Re: 17x11 50 or 56mm offset (95wht6spd)
GS offset can be used on 89-96 :D
Old Feb 16, 2003 | 03:51 PM
TA's Avatar
TA
I believe that the 17x11 ZR-1 wheels are 36mm offset and the 17x11 GS wheels are 50mm.
I'm not familiar with the 56mm offset wheels, but it sounds like they should tuck in a bit more.
Old Feb 16, 2003 | 04:05 PM
Bill Reid's Avatar
Bill Reid
Default Re: 17x11 50 or 56mm offset (TA)
You are correct. If someone makes a 56mm offset wheel in 17X11 thats great... just hope there is no inner rubbing.
:cheers:
Old Feb 16, 2003 | 04:18 PM
Izover4u's Avatar
Izover4u
the 56mm is refering to the fronts 17x9.5...
the 50mm is refering to the rears 17x11...
These are the Grand Sport offset
:cheers:
Old Feb 16, 2003 | 05:13 PM
korvettek's Avatar
korvettek
Default Re: 17x11 50 or 56mm offset (Izover4u)
no that not correct with company the 9.5 are 53mm and the 17x11 are 56 i like this better because it should tuck in more .the company is T Byrme motorsports-lt1
Old Feb 16, 2003 | 05:14 PM
korvettek's Avatar
korvettek
most cosider the 50 mm the gs offset and 38 the zr1
Old Feb 16, 2003 | 05:15 PM
korvettek's Avatar
korvettek
Default Re: 17x11 50 or 56mm offset (Coupe89)
dont it stick out a bit about 5mm to be exact
Old Feb 16, 2003 | 05:17 PM
korvettek's Avatar
korvettek
Default Re: 17x11 50 or 56mm offset (billreid1@***.net)
TByme Motorsports-lt1-1-877-4-TBYRNE
Old Feb 16, 2003 | 05:24 PM
Izover4u's Avatar
Izover4u
:nono: :nono:
56mm is the original front offset... u can even check the specs from factory GM
17x11 with a 56mm would not fit.. It would hit on the inside... If you have ever seen the 17x11 w/ 50mm it comes very very close to rubbing on the inside... the 56mm would most likely hit something...
[Modified by Izover4u, 4:34 PM 2/16/2003]
Old Feb 16, 2003 | 05:39 PM
korvettek's Avatar
korvettek
if you ever seen the 50 they stick out about 5mm and how close is it .id rather make 5mm of room on the inside than have it sticking out
Old Feb 16, 2003 | 05:49 PM
Izover4u's Avatar
Izover4u
50mm stick out less than 1/4 inch some dont even stick out, depends what vender you get your wheels from... but 56mm on the 11wheel will rub go ahead and try it ull see :lolg:
Old Feb 16, 2003 | 06:48 PM
ittlfly's Avatar
ittlfly
:iagree: Yep. The first thing they will hit is the emergency brake line on both sides. I just put on a set of 17 x 11 50+ offset and it just clears the lines by less than an index finger width....
[Modified by ittlfly, 3:49 PM 2/16/2003]
Old Feb 18, 2003 | 09:28 PM
korvettek's Avatar
korvettek
if it depends on the vender how would a person know until after moutng the wheels which could be problem if you decided to send them back ? :confused:
Old Feb 18, 2003 | 11:39 PM
Izover4u's Avatar
Izover4u
Thats the problem.. different venders use there own offsets.. that why they are replicas... Just be careful and make sure that the offsets that the vender's are claiming are correct... Order the wheels and get them spot checked... Thats what i did... :cheers:
Old Feb 19, 2003 | 03:23 AM
korvettek's Avatar
korvettek
thanks thats a good idea thanks :) :)
Old Feb 20, 2003 | 03:34 PM
Izover4u's Avatar
Izover4u
NP... :cheers:
Old Feb 20, 2003 | 04:04 PM
Red Rocket's Avatar
Red Rocket
Have the GM factory 17 X 11 GS wheels with 315's on the back. An index finger as mentioned before is about the space before rubbing. Looking at widening the wheels to 11.5 and go with 335's but will probably need a backspacer.
To 17x11 50 or 56mm offset
