Best repair manual
Old Aug 22, 2025 | 08:31 PM
Heratige's Avatar
Heratige
Default Best repair manual
Greetings,
Im a first timer, just bought my first and probably only, 1991 C4 and was wondering which repair manual you old timers have found to be the best for an old shade tree like myself. I’m not new to the classics as back in the 70’s, 80’s, and into the 90’s , I was an avid F body nut. The C4 is a Bucket list item that I can cross off the list!
any advice towards a good manual will be greatly appreciated. I’ve used both Haynes and Chilton’s in the past but it’s been over 30 years since I’ve even looked at one. Are they as competent as they used to be? Or should I look for a used one from the same era?
Old Aug 22, 2025 | 09:35 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Those both suck. Have multiple years and pictures in them and it doesn't apply to certain models on year specific troubleshooting. Good for single moms that want to change brakes and feel accomplished while boasting they are an adult accepting child support and alimony, I mean, strong and independent woman who doesn't need a man...
Get a Helms. They are year specific and what the dealers used, so you aren't hunting for a non-existent 96 LT4 wiring color code shown in a Haynes while working on an 84 cross-fire
Old Aug 22, 2025 | 09:39 PM
Heratige's Avatar
Heratige
Default Thanks
I just looked it up and I like what I see, and the ebook is cheaper than a chiltons! Thanks a lot! 😎👍
Old Aug 22, 2025 | 10:06 PM
flannel_man
Gone are the good old days I remember of Chilton books telling you gap specs for points, or valve lash adjustments. Now they copy and paste the beginning of every oil change or brake job as
Step 1; Disconnect the battery, caution, do not drink battery contents
Step 2; Jack all tires off the ground, put ramps under the wheels and six 10 ton jack stands under the frame
Step 3: Lock the ignition keys up in a biometric safe across town...
Old Aug 22, 2025 | 10:08 PM
Heratige's Avatar
Heratige
That’s funny but I can see it so….
Old Aug 23, 2025 | 12:26 AM
slammin's Avatar
slammin
Welcome to the forum. It is the most active Corvette site. Buy the GM Factory Service Manuals, don't waste your money on the others. The FSM is model year specific and can be down loaded. Being an old fart, I prefer the hard copies. I also have a 91, but mine is red. Is yours steel blue metallic? We like lots of photos. 6 speed or automatic?
Old Aug 23, 2025 | 11:00 AM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
RC, your wheels are mounted backwards. Swap the left side for the right side and vice versa.
If you Google "C4 Corvette" and click Images, you'll see what I mean.
Old Aug 23, 2025 | 03:26 PM
Heratige's Avatar
Heratige
Good grief ,they are! Haha I just bought it so I haven’t done anything to it yet, thanks. New tires coming soon so we’ll get it on right. Probably the previous owner rotated the cheap way…thanks again!
Old Aug 23, 2025 | 03:28 PM
H Watkins's Avatar
H Watkins
RC, thank you for not being offended. BTW, I do like your wheels in chrome!
Old Aug 23, 2025 | 03:34 PM
WVZR-1's Avatar
WVZR-1
No one has seen the 'other side' of the car yet. Is it safe to assume right to left fixes orientation?
Old Aug 24, 2025 | 03:32 PM
Heratige's Avatar
Heratige
No offense taken and yes they had been moved side to side. ,
Old Aug 24, 2025 | 03:34 PM
H Watkins's Avatar
H Watkins
Cool!
Old Aug 24, 2025 | 06:28 PM
mike1111's Avatar
mike1111
Greetings,
gm manual would be best.before the internet i use to buy 2 or 3 different authors and cross refrance , because i found mistakes. Haynes and chilton are fine for general maintenance. Brakes, oil change, tune up. When i was young and money was tight, i copied pages i needed from shop manual at library.
To Best repair manual
