Automatic shifter issue
Old Aug 24, 2025 | 03:44 PM
Heratige's Avatar
Heratige
Default Automatic shifter issue
Greetings,
when I try and pull the shifter in to 1st gear it won’t downshift without slapping the stick rearward. I assume the shift cable or the shifter itself needs adjustment. Where is the usual adjustment made to make it work properly? The indicator shows 1st but I have to force it to make it shift. Any suggestions will be appreciated.
Old Aug 24, 2025 | 04:03 PM
Siveck's Avatar
Siveck
Shift boot not allowing full travel? Has been an issue on these cars.
Old Aug 24, 2025 | 04:07 PM
Heratige's Avatar
Heratige
Doesn’t seem to but I’ll double check. Thanks.
Old Aug 24, 2025 | 09:50 PM
IHBD's Avatar
IHBD
Pro Mechanic
To Automatic shifter issue
