I am planning on putting together a 383 for my 91 Vette.
Forged everything and a Superram or Stealthram. But the SR or SR (?) will be later. I am going to build the low end first and then upgrade with new heads and intake when I can afford it. I was planning on using the LPE219 camshaft since that is what you guys recommend. It is going to be – not a daily driver but something that can be driven on my spare time (if the weather is nice).
I bought an old block some time ago, 4 bolt 010 block from 1969. It needs some work to be in perfect shape, but not much.
The question/problem:
- Should I keep the old block or build my new engine on a rollerblock?
- Will I be able to find a roller camshaft that is equal to the LPE219 that will fit my old block? Roller lifters? Hydraulic rollers?
- Can I find a 4-bolt rollerblock?
- Will my L98 heads fit on an old block?
- Is the supply of crankshafts that will fit in a new block as good as it is to the older blocks?
Your 91 block is a roller block. Id stay with either your current block or go with a 400.
I do not want to use the block that is in the car now. I want to save my original engine and perhaps I will restore it. Besides that I want to be able to drive the car while I am building my new engine. :cheers:
OK, why? Because it is easier to find a good camshaft and because of the 1-piece bearing?
Problem is that I live in Sweden and it is not as easy to find a good roller block as it might be where you live. But if it is much better to build it on a roller block then I will consider it.
-[QUOTE]
The Problem, is cost the retro roller lifters alone are about $500 from Comp (prices may varry). You will be able to get the cam you want for a roller block but how close is your old block (does it need machine work?). Getting a roller block for a couple hundered bucks should be no problem the cost will be in the machine work (Cleaned, bored, ect..... figure another $250). Your heads and intake will fit either block. I would try to find a cheap roller block and build it and sell your old one.
The 87 and later block are roller blocks, a 86 1 piece block would need retrolifters. Don't worry too much about looking for a 4 bolt block, a 2 block is usually strong enough and if you feel that you need 4 bolts you can have the additional 2 bolts splayed into a 2 bolt block which is actually stonger than the factory 4 bolt blocks.
Since I now have to buy a new (used) block, should I try to find a 400 block instead of a 350 roller block? Or will it be allot more expensive to build a stroker on a 400 block. :confused:
I would love to see a 427 in my Vette... :D
What about hydraulic roller camshafts and lifters that will fit in a 400 block?
All the 400 are non roller blocks, so you will need retrolifter and you will need an adapter to convert the 2 piece to a 1 piece rear main seal.
look at it this way...u want power lookin 2 the 400,big bore short stoke,retrofit it with hyr.roll.lifter cause its true they never were factory roller motors.keep your old block and build on it,if u have money put it in some after market heads,like world products because your old factory castings are about as good as they can get(machinest's advice)portings not gonna help as much as u think,pockets aren't made for it.a 400,2 piece is all u can get so just go for it
First, a piece of advice- be sure what you want and have a well thought out plan. I did not and paid ($) for it.
Second, if you're going for a 400 block, they may be hard to find in your neck of the woods. SBC blocks are not very expensive and several companies offer much improved versions, brand new. Check out...
Don't know how much you want to spend, but his 450HP 9.5:1 427 sounds pretty driveable. There is a link on that page to http://www.worldcastings.com , check out the info on thier 400 block. Very compatible to your existing components.
Enjoy, this is the most fun thing you can do TO your Corvette (w/o getting really funny looks from the neighbors)
I have a non-roller motor in my '86 and i'm rebuilding my old roller block as a spare. Why?
1. roller cam
2. one piece seal wont leak as fast (even tho my 86 has that)
3. blocks in good shape/good cores are abundant
4. you can get a 2-bolt block cheap and go with the 4 bolt caps
5. want displacement? stroke it and use a long rod
It's the next step in small block evolution.. nothing wrong with non-roller blocks, but roller blocks just give you a little more room to play
Is it only hydraulic roller lifters that wont fit in my non-roller block? Can I put in a roller camshaft and non hydraulic (solid?) roller lifters in my block, or is that not recommended?
Thank you for all your inputs. I keep hearing that I need a good plan, but I don't have one at the moment. I am trying to decide what my plan will be. So that is way I seem to be a little bit lost...
:cheers:
No...you can't do that. The cam specs would change with a different type of lifter.
