Raise the rear!!
Old Sep 19, 2025 | 10:37 PM
Bugly87's Avatar
Bugly87
Default Raise the rear!!
Hello,
1992 auto 92000 miles regular coupe. I am interested in raising the rear of my car but only an inch or 2. I have read up on lowering the car with lowering bolts, but conversely, can you raise the back of the car in a similar way? What are the best options to do this?
Thank you in advance,
Kevin
Old Sep 27, 2025 | 11:02 AM
JoBy's Avatar
JoBy
Short answer: Yes.
I found this picture with google.
The chassie is lifted by the composite spring and it is hanging in one bolt at each end.
A shorter bolt lift the spring and chassie.
A longer bolt lowers.
You can more or less use any bolt of the correct diameter, but you need to drill a hole to secure the nut with a cotter pin.
Old Sep 27, 2025 | 11:12 AM
JoBy's Avatar
JoBy
At the center spring mount there is usually some spacers you can move above or below the spring to change ride height my the same amount.
Old Sep 28, 2025 | 09:34 AM
Incorvettei's Avatar
Incorvettei
Yes it is possible but not sure why one would want to do that to a C 4.
Old Sep 28, 2025 | 11:29 AM
Bugly87's Avatar
Bugly87
Originally Posted by JoBy
Short answer: Yes.
I found this picturewith google.
The chassie is lifted by the composite spring and it is hanging in one bole at each end.
Cot can more or less use any bolt of the correct diameter, but you need to drill a hole to secure the not with a cotter pin.
Thank you very much.
Old Sep 28, 2025 | 08:14 PM
dddonkey's Avatar
dddonkey
I had to raise my driver side by tightening the bolt to get both sides of the car level (driver sat 3/4" lower than passenger side), pretty easy.
To Raise the rear!!
