RD Racing camber brace
Old Sep 21, 2025 | 01:30 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default RD Racing camber brace
Anyone use RD Racing camber brace? Curious if anyone has had it touch any portion of the engine etc and transmit vibration into the chassis.
i noticed.mine loosens over time it tilts toward ac piping and water pumo ect sensor.
Old Sep 24, 2025 | 07:10 PM
96 lt-4's Avatar
96 lt-4
I ran one years ago on my 96 and don't recall any of those problems.
Old Sep 24, 2025 | 07:16 PM
steve40th's Avatar
steve40th
Thnx, I need to maybe put better loctite on the bolts.
Old Sep 24, 2025 | 07:48 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I also had one on my 96 for a few years,never had any issues
Old Sep 24, 2025 | 08:46 PM
AZSP33D's Avatar
AZSP33D
I had a different brand, Maybe Vette 2 Vette or Van Steel or VB&P something starting with the letter V, haha.
for the earlier vette it was a straight bar with some heavy ends that could be shimmed and I used the OEM UCA forward bolts as they were long enough after a proper camber adjustment (short spacer). If never moved, it was solid. Note that the stock bolts have a square key, and this fit perfectly into the end plate slots, so it probably resists rotation more than the cheap hardware supplied. Since it’s a really heavy piece, I wanted to test back to back to back on an autocross test day, and it seemed more precise and it was a little faster, so I left it in.
But since then, I’ve removed the whole cross member, seam welded and reinforced, and also a heavy aluminum motor plate to tie the two sides together, so I sold the brace a few years ago. I suspect that the close member can fatigue and flex more after some stressful decades, so the bottom piece should be reinforced (where the leaf spring forces are focused of you still have leafs.) then there are a lot of seams in the LCA attach pockets, and then the side uprights where they attach to the frame. Other changes for me, included larger 5/16 fine thread bolts and that included a brass bushing pressed into the cross member uprights. These are bigger so I had to also ream the UCA bar (steel one from SPC)
Old Sep 25, 2025 | 09:49 AM
steve40th's Avatar
steve40th
I may take it out completely. Gives me more room for belt change, access to other items down there.
And, I dont run it hard in autocross etc anymore
To RD Racing camber brace
