Cloyes Timing Marks Explanation Needed
Old Feb 17, 2003 | 08:59 PM
89vette's Avatar
89vette
Default Cloyes Timing Marks Explanation Needed
I understand that on the Cloyes crank sprocket, the triangle is advanced, the circle straight up, and the square retarded. My question is how much? I thought it was 4 degrees advance or retard but a post on here from 2001 says its 2 degrees either way. My cam has 4 degrees advance built in already from Comp. This would mean my cam is actually 8 degrees advanced if the crank sprocket advances it 4 degrees.
Old Feb 17, 2003 | 09:15 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Cloyes Timing Marks Explanation Needed (89vette)
Cloyes says 4 degrees on the box that I had and on the website. I would trust them since they made the thing.
Old Feb 17, 2003 | 09:34 PM
scorp508's Avatar
scorp508
Crap. I was told the square was straight up and that is how I have it installed. Otherwise I agree with the fact that it is -4 and +4.
Old Feb 17, 2003 | 09:37 PM
89vette's Avatar
89vette
Default Re: (scorp508)
Scorp. Don't take my work for it. I need to call Cloyes tomorrow and ask for sure. Nathan, do you have the printed instuctions from Cloyes?
[Modified by 89vette, 8:37 PM 2/17/2003]
Old Feb 17, 2003 | 10:18 PM
ninetyfivevette's Avatar
ninetyfivevette
Default Re: (89vette)
I used pn 9-3145 and it says +/- 2 degrees on the box. I even ran out the the garage to double-check. Very odd since I agree, I read +/- 4 degrees everywhere else.
Old Feb 18, 2003 | 10:04 AM
89vette's Avatar
89vette
Default Re: (ninetyfivevette)
This really :confused: things now! The 9-3145 is the right set for factory roller cam motors. The Summit site says the crank gear allows +4 degrees either way from center. Does the box say anything about the shapes and what they mean?
Old Feb 18, 2003 | 03:12 PM
grumpyvette's Avatar
grumpyvette
on the crank gear
0 - Indicates standard cam timing
A - Advances the cam timing 4°
R or a square - Retards the cam timing 4°
[Modified by grumpyvette, 8:13 PM 2/18/2003]
Old Feb 18, 2003 | 03:20 PM
89vette's Avatar
89vette
Default Re: (grumpyvette)
Is that a Cloyes unit?
Jason
Old Feb 18, 2003 | 03:31 PM
89vette's Avatar
89vette
OK here is the deal. I called Cloyes and talked to their engineer. The Part number 9-3145 is follows:
Circle = straight up
Triangle = 4 degrees advance at crank which is 2 degrees advanced at the cam
Square = 4 degrees retard at crank which is 2 degrees retard at cam
Now we know where the confusion is. So when talking about degrees advance and retard we are discussing crank degrees right since the degree wheel is mounted on the crank.
He mentioned that he recommends the 9-3145A billet hex-a-just set for much wider control.
Jason
Old Feb 19, 2003 | 03:11 AM
ninetyfivevette
Makes perfect sense, thanks for calling to clear things up.
To Cloyes Timing Marks Explanation Needed
