TPS setting questions
Old Feb 18, 2003 | 04:53 PM
brookman's Avatar
brookman
Default TPS setting questions
I had my throttle body rebuilt because of excessive play. They put a new TPS on it and adjusted it for .68 at idle - I questioned it and he said I would like it. THe car is smooth as could be, but it seems like I lost about 2 MPG on my average. What is the effect of having it a .68 instead of .54.
Old Feb 18, 2003 | 05:00 PM
VetBoy89's Avatar
VetBoy89
Default Re: TPS setting questions (brookman)
Book spec is .54v +/- .08v (.46 - .62), .68 is set to high. Try setting it to .54v and see if it affects your mpg. :thumbs:
Old Feb 18, 2003 | 05:38 PM
chucks88's Avatar
chucks88
Default Re: TPS setting questions (VetBoy89)
I thought I read somewhere that .68 is supposed to be some kind of a performance setting. Don't remember reading that it would hurt MPG however :skep:
Old Feb 18, 2003 | 05:40 PM
scorp508's Avatar
scorp508
You can set it as high as 0.68v at idle w/o throwing a computer code. This will give you a slightly higher idle and a very small increase in throttle response.
To TPS setting questions
