85 Vette carb swapped
Old Nov 8, 2025 | 11:02 PM
GoldCocvette's Avatar
GoldCocvette
1st Gear
Default 85 Vette carb swapped
Hey guys, recently picked this 85 Vette in rough shape that has been carb swapped, runs and drives good, all guages work except fuel level guage. The engine is not ran off the stock pump but I was wondering if I could hook up the wires for the level sensor thing and if it would work? I've looked and can't find a diagram or anything of what pin does what on the fuel pump connector so if someone has that, that would be great.
Old Nov 10, 2025 | 03:27 PM
wilcar's Avatar
wilcar
Just run a new 12 ga wire through a fuse back to the fuel gauge sender. Did this on my 84 C4 when I carbed it 10 years ago. No problems so far! Good luck!
