Anyone running a 383ci have advice on where the fuel pressure
should be at idle...I've got #24 lb injectors w/superram intake
and a TPIS level 5 chip...but my idle is constantly hunting/sputtering...
have a new IAC motor in and the TPS is set to spec..52mm tb w/ no
apparent air leaks...Any suggestions greatly appreciated
:cheers:
That's kind of a trick question, it's probally not going to be as much as you may think. Could be anthing from 38-48psi. My car likes 45ish +/- a few psi.
:cheers:
Your best bet here is going to be to talk to TPIS and see what fuel pressure and injector size the chip thinks is in the motor. Hopefully their program assumes the #24 injectors you have and it's a simple adjustment on the regulator. However, if the chip is thinking you have #30s, you'll need to crank it up some more.
