intake gasket set
Old Nov 15, 2025 | 04:48 PM
rochhound's Avatar
rochhound
Default intake gasket set
instaling intake gasket felpro came with with two metal plugs for center hole in intake gasket should i install them or leave them out?
they block the center hole cant remember if i should use or not
Old Nov 15, 2025 | 05:30 PM
Tunedport90's Avatar
Tunedport90
If it’s later year 128 or 113 head tpi it doesn’t matter. That’s a side feed for egr . C4 tpi uses the rear feed. The head doesn’t have the port so it’s blocked.
