Service engine light turned on three times on me today in the morning on my way to work. And once coming home. Here are the codes 24, 34, 36. I know I had a 36 code for a while and I needed to replace the burn off relays but I have three manuals telling me three different things for codes 24 and 34. Can anyone help? Are codes 24 and 34 a direct correlation to the fact that I have not fixed code 36 the burn off relays?
Oh one last thing, I really need to drive the car to work in the rest of the week as the daily driver is out of commission until Saturday, do you all think I can still drive it until then or find some other way until I get at least the relays?
I would start with both relays they are cheap enough. My faulty MAF was causing hesitation, sputtering etc. when mine was on its way out but still tripped no codes.
:iagree: Start with the MAF relays on the firewall behind the battery. They are only $20 for both and the MAF is $160 for a backordered used one from ZIP.
In my experience with my '87, there doesn't seem to be any correlation between a code 36 and code 34. I have had a bad MAF burnoff relay for 3-1/2 years (yes, I'm just too lazy to fix it) and have only gotten a code 34 when the MAF was actually bad.
Welcome to the 30something club. Seems pretty popular and tough to fix. I had all the codes you listed except for the 24. I replaced everything that touched the MAF and still have an intermittant 33. I haven't had it for a few days but I know it will come back to visit.
If your not going into limp-home mode, I'd drive it until you have time to fix.
Thanks to all, I will change the relays and see what happens. My dealer charges $18 for each but better than $150 for the MAF. I will let you all know if it gets fixed.
One last dumb one for the road. When I replace them should I disconnect the negative from the battery so that it resets itself? Or just plug new ones and drive?
OK guys put in the new relays and codes 34 and 36 disappeared but code 24 is still shooting out. I looked it up and it tells me it is "24 Vehicle Speed Sensor (VSS) or circuit" if this is true were in the hell is this sensor? Thanks
